1MII LAVAUDIO DS200 PRO Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Black
The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution transmission like the aptX, the aptX LL, the aptX HD or the LDAC for a listening of great quality, even in wireless.
Reference : 15299
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 22-04-2025.
1Mii DS200 Pro
Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018K2M
Récepteur Bluetooth 5.0 CSR8675 DAC ES9018K2M 32bit 384kHz
The conversion stage is entrusted to an ESS ES9018K2M DAC chip, in charge of processing and converting digital audio data into analog. The latter supports high sampling rates, up to PCM 32bit 384kHz, and ensures excellent audio performance, with a dynamic range of 127dB and a THD+N of -120dB.
On the connectivity side, there are RCA output as well as a digital optical output for maximum compatibility with your current audio system.
Product typeBluetooth reception
Bluetooth chipQualcomm CSR8675
Bluetooth version5.0
Supported Bluetooth codecsAAC, SBC, aptX, aptX HD, aptX LL, LDAC
DAC ChipESS ES9018K2M
Outputs1x Stereo RCA
1x Optical Toslink
Dynamic range127dB
THD+N-120dB
Dimensions105 x 90 x 26mm
Package1x 1Mii DS200Pro
1x Power cable
1x Female Jack 3.5mm to Male RCA cable
1x Optical cable
1x RCA Cable
4x Rubber feet
OutputOptical Toslink
DAC / ADC ChipES9018
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsSBC
2 reviews
Super son ! pas déçu du tout !
Son d’enfer. Je redécouvre mes morceaux et albums MP3 320Kb
+ Plus de coupure ou de saut de la connexion (Bluetooth 5.0) et plus de ralentissement bizarres pouvant survenir pendant l'ecoute
Heureux !
This review has been posted for 1MII LAVAUDIO DS200 PRO Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Black
2eme en commande
Le son est excellent pour écouter les redifs arte concert sur youtube depuis le laptop ou le portable. Mes deux chaînes seront équipées
The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs...
