AOSHIDA BLAD-S5 Bluetooth Receiver / FM Radio / DAC
The Aoshida BLAD-S5 Bluetooth / FM receiver is a device featuring many high-quality components. It incorporates a Qualcomm QCC5125 Bluetooth receiver chip, an ES9038 DAC chip, as well as OPA1656 and a CS8406 SPDIF converter. The QCC5125 Bluetooth 5.1 receiver chip supports the following high-definition Bluetooth codecs: aptX, aptX Adaptive, aptX HD and LDAC.
Reference : 19592
99,00 €tax incl.
82,50 € tax excl.
Aoshida BLAD-S5 Bluetooth 5.1 Receiver / FM Radio DAC ES9038
AOSHIDA BLAD-S5 picture
The Aoshida BLAD-S5 Bluetooth / FM receiver is a device featuring many high-quality components. It incorporates a Qualcomm QCC5125 Bluetooth receiver chip, an ES9038 DAC chip, as well as OPA1656 and a CS8406 SPDIF converter. The QCC5125 Bluetooth 5.1 receiver chip supports the following high-definition Bluetooth codecs: aptX, aptX Adaptive, aptX HD and LDAC (990kpbs - 24bit/96kHz). The ES9038 DAC chip and CS8406 SPDIF interface ensure digital-to-analog signal conversion for lossless wireless reception. Several analog and optical/SPDIF outputs are available: stereo RCA, coaxial SPDIF and Toslink optical. This device also offers the possibility of enjoying FM radio and USB DAC use via its USB-C input/power port. A large LCD display and a control interface with numerous buttons make for easy navigation, and display a wide range of information on the BLAD-S5's current playback and operating mode.
AOSHIDA BLAD-S5 highlights
Aoshida BLAD-S5 : Bluetooth 5.1
The QCC5125 Bluetooth receiver chip offers a new level of high-definition wireless reception, enabling the Aoshida BLAD-S5 to support the following high-definition codecs: aptX, aptX Adaptive, aptX HD and LDAC. In particular, LDAC enables wireless transmission superior to CD quality, with a sampling rate of up to 24bit 96kHz and a transmission speed of up to 990kpbs.
Bluetooth reception of the AOSHIDA BLAD-S5
Aoshida BLAD-S5 : FM receiver
The Aoshida BLAD-S5 is more than just a Bluetooth receiver: it also features FM reception, so you can enjoy your favorite radio stations. FM transmission is also possible over a range of up to 20m.
FM radio access for AOSHIDA BLAD-S5
Aoshida BLAD-S5: high-end components
AOSHIDA BLAD-S5 ES9038 DAC chip
DAC ES9038
Converts Bluetooth or USB digital streams to the BLAD-S5's analog RCA output.
AOSHIDA BLAD-S5 CS8406 SPDIF interface
Converts digital signals to the BLAD-S5's SPDIF coaxial and Toslink optical outputs.
AOSHIDA BLAD-S5 OPA1656
OPA1656
These OPAs deliver excellent performance, with good dynamic range and low distortion, for quality sound reproduction at the BLAD-S5's outputs.
Aoshida BLAD-S5: large LCD screen and intuitive interface
A large 2.4" LCD screen displays a wealth of information, making navigation and control of the BLAD-S5 simple and intuitive. The user experience is further enhanced by an IR remote control.
AOSHIDA BLAD-S5 interface and remote control
Aoshida BLAD-S5 overview
AOSHIDA BLAD-S5 overview
1IR receiver
2Bluetooth antenna
3Display
4Control buttons
5Stereo RCA output
6SPDIF coaxial output
7FM antenna connector
8Toslink optical output
9Bluetooth antenna connector
10USB-C DAC input / Power port
Product typeBluetooth receiver / FM radio
Bluetooth chipQCC5125
DAC chipES9038
SPDIF interfaceCS8406
OPAsOPA1656
Inputs1x USB-C
Bluetooth
FM radio
Outputs1x RCA analog stereo
1x Coaxial SPDIF
1x Optical Toslink
FM radio
Supported Bluetooth codecsSBC, AAC, aptX, aptX Adaptative, aptX HD, LDAC
Bluetooth range10m unobstructed
Distorsion0.07%
SNR≥ 98dB
Input sensitivity0dBFS
Output amplitude2.5Vrms
Frequency response20Hz-20kHz (+/-1dB)
IR Remote control
Power supply5V/1A DC via USB-C (do NOT use fast-charge adapter)
Dimensions89 x 125 x 54mm
Gross weight0.78kg
Package1x Aoshida BLAD-S5
1x Bluetooth antenna
1x FM antenna
1x Toslink optical cable
1x USB-A to USB-C cable
InputFM
OutputModulation FM
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9038Q2M
Transmission / Reception protocolUHF/RF
Supported Bluetooth codecsaptX
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
AOSHIDA BLAD-S5 Bluetooth 5.1 Receiver / FM Radio DAC ES9038
The Aoshida BLAD-S5 Bluetooth / FM receiver is a device featuring many high-quality components. It incorporates a Qualcomm QCC5125 Bluetooth...
