The Arylic BR10 is a small Bluetooth receiver that will enhance your existing sound system. In addition to its Bluetooth 5.0 receiver functionality, which enables it to support aptX, aptX Adaptive and aptX HD high-definition codecs, it also features a USB DAC function. In terms of connectivity, the Arylic BR10 is equipped with the essentials: a USB-C input, a USB-A (USB Host) input, a 3.5mm stereo line-in jack, as well as a Toslink optical output and a 3.5mm stereo line-out jack. The Arylic BR10 supports sampling rates up to PCM 24bit 192kHz. To top it all off, Arylic provides its free Go Control APP for easy device control, and even custom EQ settings. The Arylic BR10 therefore boasts a number of interesting features in a compact form factor that makes it easy to integrate into an existing sound system, and at a very affordable price.
The Arylic BR10 benefits from a Qualcomm QCC3040 Bluetooth reception chip, enabling it to support AAC, SBC, aptX, aptX Adpative and aptX HD codecs over a range of up to 15m without obstacles. This Bluetooth chip offers stable reception and extended compatibility with devices from Bluetooth 4.0 to Bluetooth 5.4.
Thanks to its USB-C input/power port, the BR10 can be used as a USB DAC. It supports sampling rates up to PCM 24bit 192kHz for the Toslink optical output and up to PCM 16bit 48kHz for its 3.5mm jack line output. So you can enjoy CD-quality audio streams, whether wired or wireless with the BR10.
The Arylic BR10 allows simultaneous signal transmission via its Toslink optical output and 3.5mm jack line output. This makes it easy to pair with a 2.1-channel sound system and enjoy immersive sound with an active subwoofer.
The Go Control APP gives you easy remote control of the BR10, and access to a wide range of equalization settings for personalized sound according to the type of music being played and your tastes.
The ACPWorkbench tuning tool lets you customize your audio experience. With this tool, you can adjust frequency on each channel, adjust channel balance, customize deep EQ settings and more.
ACPWorkbench software sold separately. You can buy it on Arylic website.
The BR10 can also be controlled remotely by remote control, for the most pleasant user experience.
1 | ON/OFF button |
2 | Volume - |
3 | Play / Pause |
4 | Volume + |
5 | Toslink optical output |
6 | 3.5mm stereo jack line input |
7 | 3.5mm stereo jack line output |
8 | USB-A port (USB Host) |
9 | USB-C input / Power port |
Product type | Bluetooth receiver |
Bluetooth chip | QCC3040 |
Inputs | Bluetooth 1x USB-C input (DAC) 1x USB-A input (USB Host) 1x 3.5mm stereo jack input |
Outputs | 1x 3.5mm jack line output 1x Toslink optical output |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX Adaptive, aptX HD |
Supported sampling rates | USB DAC : PCM up to 16bit 48kHz |
Input line level | 2Vrms max. |
Line output level | 2Vrms max. |
USB Host compatibility | File systems supported: FAT16, FAT32, exFAT, up to 128GB Supported formats: MP3, MP4, WMA, MOV, M4A, AAC, FLAC, APE |
Bluetooth range | 15m |
Power supply | 5V 1A via USB-C |
Dimensions | 108 x 72 x 26.6mm |
Weight | 89g |
Color | Black |
Package | 1x Arylic BR10 1x Remote control 1x Jack 3.5mm cable 1x RCA 2 to 1 cable 1x Power supply 1x USB-C cable |
Input | USB |
Input | Bluetooth |
Input | Jack 3.5mm |
Output | Jack 3.5mm |
Output | Optical Toslink |
DAC / ADC Chip | NC |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX Adaptive |
