Audio Transmitter Receiver Bluetooth 5.0 aptX HD / LL CSR8675
This Bluetooth 5.0 audio sender and receiver combo is particularly practical when integrated into a HiFi installation. It allows you to remotely transmit or receive audio streams via Bluetooth.
4.5 / 5
Reference : 14724
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 18-04-2025.
Bluetooth Transmitter / receiver
Émetteur / Récepteur Bluetooth 5.0 aptX HD / LL CSR8675
This Bluetooth 5.0 audio sender and receiver combo is particularly practical when integrated into a HiFi installation. It allows you to remotely transmit or receive audio streams via Bluetooth. A switch on the side of the device allows you to select its operating mode: TX for transmitter mode and RX for receiver mode. It also integrates a Toslink optical input and output as well as a 3.5mm jack output. An integrated 300mAh battery provides 10 hours of autonomy in transmission and 12 hours in reception for a charging time of only 2 hours, via Micro USB.
The device includes a Qualcomm CSR8675 Bluetooth chip that supports the standard SBC and AAC transmission codecs as well as the aptX, aptX HD and aptX LL codecs. These codecs enable fast, latency-free, high-quality audio streaming to achieve near CD-quality playback over Bluetooth.
Transmitter Mode
Receiver Mode
Émetteur / Récepteur Bluetooth 5.0 aptX HD / LL CSR8675 Émetteur / Récepteur Bluetooth 5.0 aptX HD / LL CSR8675
1Status LED
2ON/OFF Switch
3Power ON LED
4Pairing button
5Transmitter / Receiver switch
6SPDIF / Aux switch
7Aux connector
8SPDIF Optical Toslink input
9SPDIF Optical Toslink output
10Micro USB charging connector
11Volume + / Previous track
12Pause / Play / Answer phone call
13Volume - / Next track
14LED
Product typeBluetooth Transmitter / Receiver
Bluetooth chipCSR8675
Bluetooth version5.0
Supported Bluetooth codecsAAC
SBC
aptX
aptX HD
aptX LL
AutonomyTransmitter mode : 10h
Receiver mode : 12h
Charging time2h
Charging connectorMicro USB
InputsBluetooth
1x Optical Toslink
OutputsBluetooth
1x Optical Toslink
1x Jack 3.5mm
Integrated controlsVolume
Play/Pause
Next/Previous track
Answer phone call
Dimensions65 x 55 x 18.5mm
Package1x Bluetooth Transmitter / Receiver
1x Optical cable
1x Micro USB charging cable
1x Jack 3.5mm cable
OutputJack 3.5mm
OutputOptical Toslink
OutputBluetooth
DAC / ADC ChipNC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX
4 reviews
Very worthwhile
Bluetooth in aptx-hd from phone (andoid) or linux desktop. Toslink feed into teac ha-p50se or fiio E17. Really notice the SQ improve with the hd codec. They say xq-sbc codec (linux) is as high- quality as aptx-hd, but to my ears, aptx-hd is much finer quality.
On phone, the connection works well over several meters, less on the laptop. This device lasts me about 12h in RX mode.
Very happy with this product. I can fully recommend. Shipping to Finland was easy and hassle free. Item arrived within about 8 days.
This review has been posted for Audio Transmitter Receiver Bluetooth 5.0 aptX HD / LL CSR8675
Notice très succinte et câble USB court, mais fonctionne très bien. Les voyants pour indiquer le protocole BT utilisé sont très pratiques.
Pont bluetooth
J'ai pris deux unités pour faire une connexion point à point bluetooth pour relier videoprojecteur et enceintes à l'autre bout de la pièce. Pas de délais ressentis entre audio et vidéo mais un son un poil plus bas qui oblige a régler entre film et musique (à régler sur l’émetteur peut être). Je remercie le service client pour ses bons conseils.
bon produit
fait le job , bonne connectique et fonctionnalités
bonne tenue de la batterie
mais toujours une notice chinois /anglais même si l utilisation est intuitive une notice en Français serait la bienvenue et en principe obligatoire
This Bluetooth 5.0 audio sender and receiver combo is particularly practical when integrated into a HiFi installation. It allows you to remotely...
