AUDIOPHONICS Q6 Bluetooth 5.4 Receiver QCC3084 DAC ES9018K2M aptX HD LDAC
The Audiophonics Q6 is a small Bluetooth receiver combining a Qualcomm QCC3084 chip and an ES9018K2M DAC chip. It supports aptX HD (24bit 48kHz) and LDAC (24bit 96kHz) codecs for high-fidelity wireless listening.
Reference : 14210
55,90 €tax incl.
46,58 € tax excl.
Photo of AUDIOPHONICS Q6 Bluetooth receiver
The Audiophonics Q6 is a small Bluetooth receiver combining a Qualcomm QCC3084 chip and an ES9018K2M DAC chip. It supports aptX HD (24bit 48kHz) and LDAC (24bit 96kHz) codecs for high-fidelity wireless listening. It can also be connected to a source such as a computer via the USB-C port to power it and send an audio signal directly to the ES9018K2M DAC chip. Output, meanwhile, is via 3.5mm jack. You can output directly to a power amplifier, active speakers, headphones or IEMs.  There are also two volume control buttons on the front panel and two microphones on the rear panel for Bluetooth call support.
Interior photo of AUDIOPHONICS Q6
USB 5V power adapter not included.
Product typeBluetooth receiver
DAC
Bluetooth chipQCC3084
DAC chipESS ES9018K2M
InputsUSB-C
Bluetooth
OutputsJack 3.5mm stereo
Supported Bluetooth codecsSBC, AAC, aptX HD, LDAC
Bluetooth range10m
Power supply5V DC via USB-C
Dimensions63 x 67 x 20 mm
Weight90g
Package1x Audiophonics Q6 Bluetooth receiver
1x USB-A to USB-C cable
1x 3.5mm stereo jack to RCA cable
OutputJack 3.5mm
DAC / ADC ChipES9018K2M
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsAAC
4 reviews
Son imbattable, rond et précis. Attention switch BT complexe
Je l'ai depuis 4 ans maintenant pour l'interface entre mon PC et ma chaine hi-fi (NAD basse/moyenne gamme). Imbattable sur la qualité sonore, j'ai testé d'autres DAC de sa catégorie et je n'ai jamais obtenu un son aussi rond, complet, précis, agréable. Convient parfaitement pour une connexion BT unique et stable. Car pour switcher d'appareil, il faut hélas l'éteindre, le rallumer et établir une nouvelle connexion. Idem quand on veut remettre l'ancien. Dommage qu'il n'y ait pas au minimum un bouton de réinitialisation BT.
This review has been posted for AUDIOPHONICS Q6 Bluetooth 5.4 Receiver QCC3084 DAC ES9018K2M aptX HD LDAC
Épatant
Branchements simples, reconnaissance immédiate de l'appareil depuis un smartphone Androïd. Utilisé avec Qobuz, relié en RCA à un ampli Marantz sans entrée numérique. Écoute grâce à des enceinte Jersey Cabasse : c'est exactement ce que je souhaitais. Ça marche parfaitement, la qualité est surprenante. Il semble que le bluetooth, que l'on dénigre beaucoup, progresse bien vite. Merci à Audiophonics qui propose du si bon matériel, minuscule , à un prix très raisonnable et d'une belle efficacité. Reçu dans les délai. Emballage parfait.
super qualité audio 24bits 384 kHz
J'ai 3 modules TX/RX Bluetooth et celui ci fournit la meilleurs qualité audio et de loin. Un simple chargeur USB de tel est suffisant pour le faire fonctionner.
Fait l'affaire !
Fonctionne parfaitement, le son est bon. Parfait pour le pour le prix.
P.S. à l'attention d'audiophonics : l'alimentation que vous préconisez sur votre site n'est pas adaptée au récepteur car ce dernier possède une entrée en USB C alors que l'alim. est encore avec l'usb première génération. Donc l'alimentation que j'ai reçue ne me sert à rien, dommage.
The Audiophonics Q6 is a small Bluetooth receiver combining a Qualcomm QCC3084 chip and an ES9018K2M DAC chip. It supports aptX HD (24bit 48kHz)...
