Discover the Avantree Priva III, the first Bluetooth audio transmitter the world's latest transmission technology "apt-X Low Latency" 2 devices simultaneously. Enjoy high quality audio with virtually non-existent latency./ P>
This Apt-X Bluetooth Transmitter is ideal for wireless audio streaming from your TV, PC, laptop, iPod or other audio device analogue output: 3.5mm Jack orRCA Stereo .
This PRIVA III is powered simply by being connected via its micro USB port to your TV, or any other device with a USB port. In order to be directly operational, this transmitter bluetooth comes with all the necessary connections: a cable RCA male to female, a cablep: //www.audiophonics.com/en/cables-hubs-usb-c-458.html "target =" _ blank ">micro USB to USB-A, and a 3.5mm stereo jack cable.
Technical specifications:
- Chipset CSR8670: Bluetooth 4.2
- Bluetooth Profile: A2DP
- Audio Codec: apt-X Low Latency / apt-X / SBC / Fast Stream
- Operating range: Up to 30 meters
- Multipoint: Works with 2 devices connected simultaneously
Connectivity / Packaging:
- AUX Jack 3.5mm Stereo Jack
- Micro USB port for power supply
- Dimensions: 48x48x15mm
- Weight: 16g (Transmitter) + 7g (base)
- Comes with: User manual / Magnetic base / Micro USB to A-cable / 3.5mm Jack cable / RCA male to female cable
