Bluetooth 5.0 Receiver AptX-HD CSR8675 DAC PCM5102 24bit 48kHz
This Bluetooth receiver includes a CSR8675 chip with the Bluetooth 5.0 standard and supports the aptX and aptX-HD protocols. It therefore has a higher transmission rate and stability than standard Bluetooth and therefore allows the most accurate audio playback. In addition, this chip, combined with a PCM5102 DAC, supports PCM sampling rates up to 24bit 48kHz.
Reference : 13868
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 22-04-2025.
Bluetooth receiver
Bluetooth 5.0 aptX-HD CSR8675 DAC PCM5102 24bit 48khz
Récepteur Bluetooth 5.0 CSR8675 DAC PCM5102 24bit 96kHz
This Bluetooth receiver includes a CSR8675 chip with the Bluetooth 5.0 standard and supports the aptX and aptX-HD protocols. It therefore has a higher transmission rate and stability than standard Bluetooth. In addition, this chip, combined with a PCM5102 DAC, supports PCM sampling rates up to 24bit 48kHz. Enough to enjoy your favorite songs in high resolution! A PDO just before the stereo RCA output amplifies the signal. Mounted on a DIP8 bracket, it can easily be modified to adapt the sound to your listening and your audio system.
Product typeBluetooth receiver
Bluetooth chipCSR8675
Bluetooth version5.0
Supported Bluetooth protocolsaptX
aptX-HD
DAC ChipPCM5102
Supported sampling rate24bit 48kHz
Line output1x Stereo RCA / 1x Stereo Jack
Dimensions72.5 x 80 x 29.6mm
Voltage supply12V DC via Jack DC 5.5/2.1mm (power supply sold separately)
Housing materialBrushed Aluminium
Package1x Bluetooth receiver
1x Bluetooth antenna
DAC / ADC ChipPCM5102
Supported Bluetooth codecsSBC
Supported Bluetooth codecsAAC
10 reviews
Livré sans alimentation !
Effectivement c'est écrit en petit dans la description détaillée mais ce récepteur bluetooth est livré sans alimentation et ce n'est pas une alimentation USB C donc il faut l'alimentation spécifique 12V. Dommage
This review has been posted for Bluetooth 5.0 Receiver AptX-HD CSR8675 DAC PCM5102 24bit 48kHz
Bluffant
Associé au bt20a pro de fosi audio, ça devient plus intéressant. Ce qui surprend le plus, ce sont les graves, très présent, il faut pouvoir régler le gain.
Fait parfaitement le job et sa petite preamplification est vraiment très appréciable pour des enceintes à faible rendement donc difficiles à driver.
Ravi !
Simplicité, fonctionnalité, musicalité pour du "Bluetooth".
Produit épatant.
parfait, très content
Acheté en remplacement d'un IFI Zen V2 qui n'arrêtait pas de faire des micro coupures dans le flux. Un violon qui se coupe ce n'est pas possible.
Aussitôt branché, aussitôt trouvé par l'ordinateur. Le son est parfait, un peu plus chaud et un poil moins défini que le processeur Sabre de l'IFI Zen, mais ce sont des affaires de gout.
Pour 65 euro c'est un appareil fantastique, bien construit. Et surtout, depuis 4 heures d'écoute aucune coupure, même si j'ai traversé la pièce et donc les ondes Bluetooth des nombreuses fois. Envoi rapide, rien a dire.
Excelent petit DAC Bluetooth
Fonctionne parfaitement avec une parfaite stabilité de connexion et un son qui me plaît.
This Bluetooth receiver includes a CSR8675 chip with the Bluetooth 5.0 standard and supports the aptX and aptX-HD protocols. It therefore has a...
