Bluetooth Audio Wall receptor to RJ45 Source Keypad
This wall module incorporates a Bluetooth receiver allowing the signal to be conveyed over a CAT6 cable to an RJ 45 / RCA converter. All you have to do is pair your compatible smartphone or tablet (laptop) with the "pairing" button on the built-in front.
Reference : 11086
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 16-04-2025.
It is thus possible to integrate Bluetooth technology discreetly into the recessed wall and convey the sound via an RJ 45 cable concealed in the partitions and connect its traditional Hi-Fi system with the proprietary RJ45 / RCA module.
The module RJ45/RCA can be found here : Fiche 11085.
Datasheet:
Wall-mounted Bluetooth module with pairing button.
Dimensions :
 12,5 x 8 cm
Fixing center distance : 10 cm
OutputRJ45
DAC / ADC ChipNC
ColorSilver
Supported Bluetooth codecsN/A
This wall module incorporates a Bluetooth receiver allowing the signal to be conveyed over a CAT6 cable to an RJ 45 / RCA converter. All you have...
