IEAST AUDIOCAST BA10 Bluetooth Receiver 4.2 aptX with Microphone
Reference : 13097
24,90 €tax incl.
20,75 € tax excl.
iEast AudioCast BA10
iEast AudioCast BA10 Récepteur Bluetooth 4.2 aptX avec Microphone Compatible Car Audio
A complete and affordable Bluetooth receiver
The iEast AudioCast BA10 is an accessible Bluetooth 4.2 receiver with many features and very good audio performance. Thus, it will allow you to offer your system a convenient Bluetooth reception to stream your music from your sofa, but can also adapt for an audio system in a vehicle, also acting as a hands-free kit.
Efficient Bluetooth transmission
This receiver has Bluetooth version 4.2. This allows to improve the transmission speed and its stability, but especially to connect 2 devices simultaneously. Therefore, if another person is already connected to the AudioCast BA10, there is no need to disconnect it to enjoy the device.
The integrated chip also benefits from Qualcomm's aptX technology. This also greatly increases transmission speed and stability, for a much better sound reproduction.
ieast audiocast ba10 aptx
Drive in music
The AudioCast BA10 can connect to your vehicle's audio system via 3.5mm jack (USB power supply). Once plugged in, simply connect your smartphone via Bluetooth and enjoy your music. In addition, the BA10 has a microphone, allowing you to receive and answer your calls directly.
ieast audiocast ba10 car audio
Easy to use
Step 1
Connect the USB power supply and the 3.5mm Jack cable to turn on the unit and press the multi-function button to enter pairing mode.
Étape 2
On your smartphone, go to Bluetooth settings, search and connect to AudioCast Ba10 once detected.
Étape 3
Once connected, all you have to do is play your favorite songs to enjoy them.
ieast audiocast ba10 récepteur bluetooth
Robust design
The AudioCast BA10 benefits from a neat design, with a circular and original aesthetic. The device is also robust as it offers a Zinc alloy housing, rubber seals and perfectly calibrated component integration.
In addition, it has an LED indicating the status of the device:
StatusLEDVoice alertMultifunction button
Power onBlue, blinks twice"Bluetooth device has started"/
Power off///
Pair modeBlue, blinks"Bluetooth Pair Mode"Press 3 seconds
ConnectedBlue, continuous"Bluetooth connected"/
DisconnectedBlue, blink twice per every 2 seconds"Bluetooth disconnected"/
Clear dataBlue, blinks"Clear settings"Press more than 6 seconds
Music modeBlue, continuous/Short press : Play / Pause
Double press : Next
Call modeBlue, continuous/Short press  : Hang off
Press more than 1s : reject call
Dimensions
Bluetooth versionBluetooth 4.2
Bluetooth protocolsaptX
AVRCP 1.6
A2DP 1.3
HFP 1.6
Micro sensitivity-38dB
SNR> 90dB
THD< 0.1%
Bandwidth2.402GHz - 2.480GHz
Distance10m
Audio outputJack 3.5mm
Power supply> 500mA via Micro USB
OutputJack 3.5mm
ColorGray
AudioCast BA10 récepteur Bluetooth - parfait
Enfin un produit simple et de grande qualité pour l’écoute de sa musique en streaming dans un véhicule non équipé d’origine. Branchement et mise en route très simple, intégration parfaite dans notre Range Rover L322 et son Logic 7.
La connexion avec IPhone est rapide pour la mise en route, la reconnaissance s’effectue ensuite automatiquement.
Permet la connexion simultanément de son téléphone avec le système Bluetooth intégré du véhicule pour les appels et la musique en streaming via le récepteur AudioCast.
Restitution du son assez bluffant.
Très satisfait du produit ainsi que de suivit commande.
This review has been posted for IEAST AUDIOCAST BA10 Bluetooth Receiver 4.2 aptX with Microphone
