IFI AUDIO ZEN AIR BLUE Bluetooth 5.1 Receiver aptX HD LDAC LHDC
The iFi Audio Zen Air Blue is a powerful and affordable Bluetooth receiver that will allow you to control and send your music to your audio system remotely, directly from your smartphone or tablet. Unlike most other Bluetooth receivers, the Zen Air Blue uses not just a standard SOC (integrated circuit), but a combination of high quality components to deliver the most accurate and musical sound possible. For example, the Qualcomm Bluetooth receiver chip redirects the digital signal to an ESS Sabre digital-to-analog converter. Jitter is then eliminated by a femtosecond clock. An architecture which allows to reach very good sound performances in wireless.
Reference : 16629
99,00 €tax incl.
82,50 € tax excl.
Last items in stock !
Shipping date: 01-04-2025.
iFi Audio Zen Air Blue Récepteur Bluetooth 5.1 aptX HD LDAC LHDC
Enhanced Bluetooth 5.1 reception
Zen Air Blue supports all current Bluetooth audio codecs, including high resolution protocols. SBC, AAC, aptX, aptX HD, aptX LL, aptX Adaptive, LDAC and LHDC are all supported to match your transmitting device and provide the best possible solution.
Product typeBluetooth receiver
InputBluetooth 5.1
Output1x Stereo RCA
Bluetooth chipQualcomm QCC5100 Series
Bluetooth version5.1
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, aptX LL, aptX Adaptive, LDAC, LHDC
Frequency response20Hz-20kHz +0/-0.5dB (44.1kHz)
1Hz-44kHz +0/-3dB (≥ 88.2kHz)
Output voltage @ 0dBFS2.05V (±0.05V)
Dynamic range109dB(A)
SNR109dB(A) @ 0dBFS
THD+N< 0.0015% 10kΩ @ 0dBFS
Output impedance< 50Ω
Supply voltage5VDC ≥0.5A (USB-A to DC jack cable included, AC adapter sold separately)
Consumption< 2.5W
Dimensions158 x 100 x 35mm
Weight295g
DAC / ADC ChipNC
ColorWhite
Supported Bluetooth codecsaptX
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsHWA LHDC
The iFi Audio Zen Air Blue is a powerful and affordable Bluetooth receiver that will allow you to control and send your music to your audio system...
