Multizone RJ45 to RCA Converter
Reference : 11085
75,00 €tax incl.
62,50 € tax excl.
This easy-to-use module is compatible with the corresponding Source Keypad Bluetooth wall-mounted receiver.
It allows, via a proprietary protocol, to carry a stereo signal over an RJ45 CAT6 cable and output it on a stereo RCA pair.
This allows for an elegant Bluetooth wireless wall solution that is compatible with a conventional hi-fi installation.
The volume level can be adjusted separately on the two stereo RCA outputs.
Please note that this product requires a category 6 RJ45 cable to work best with the corresponding Bluetooth module.
Features:
  • 2x RJ45 inputs (proprietary format).
  • 2x stereo RCA outputs with adjustable volume (potentiometer).
  • 94x70x30mm.
  • 370g.
  • Supplied without transformer. (Requires 12V DC adapter on 1.4mm connector).
InputRJ45
DAC / ADC ChipNC
Transmission / Reception protocolN/A
Supported Bluetooth codecsN/A
