Roxa Stereo Audio Receiver Bluetooth 4.0 aptX + Charger 1A
Reference : 7153
36,90 €tax incl.
30,75 € tax excl.
Here is finally a solution that many of us were waiting for, this small adapter lined with a 1A USB charger to the capacity thanks to the technology used to wirelessly receive music streams in CD quality.
Where does the difference lie? This small design box has the latest technical advances in the field, Bluetooth 4.0 with the adoption of the Apt-X codec.
Compatible with all Bluetooth devices AD2P, it offers a reproduction very close to CD-Audio thanks to a low compression ratio. Thus, FLAC, Apple Lossless or PCM audio files are rendered almost perfectly.
Qand native files in MP3 or AAC (with a bit rate less than 350Kbits / sec), they are transmitted without decoding and without any degradation.
Due to its compact design and ease of use, this small receiver will allow you to listen to your favorite songs on your audio system from any Bluetooth source.
Either the vast majority of Smartphone, Tablet PC, iPhone, iPad ...
Specifications:
  • Bluetooth: APT-X (+ AD2P)
  • Profiles: AD2P and AVRCP
  • Applicable with two devices simultaneously
  • Range: 10 m class II
  • Audio Output: On 3.5 Stereo Jack
  • USB charger 1A (ideal for charging your smartphone or tablet)
  • Dimensions 56x60x15mm
  • Weight: 50 g
  • Comes with the audio connection required to connect to a stereo system
https://www.audiophonics.fr/images2/6518/6518_ADVANCEWTX500_4.jpg
https://www.audiophonics.fr/images2/7153/7153_ROXA_APTX_BLUETOOTH_4.0_1.jpg
https://www.audiophonics.fr/images2/7153/7153_ROXA_APTX_BLUETOOTH_4.0_3.jpg
https://www.audiophonics.fr/images2/7153/7153_ROXA_APTX_BLUETOOTH_4.0_2.jpg
https://www.audiophonics.fr/images2/7153/7153_ROXA_APTX_BLUETOOTH_4.0_4.jpg
https://www.audiophonics.fr/images2/7153/7153_ROXA_APTX_BLUETOOTH_4.0_5.jpg
https://www.audiophonics.fr/images2/7153/7153_ROXA_APTX_BLUETOOTH_4.0_6.jpg
bien et vite reçu.Aprés un appairage avec une tablette samsung galaxy tab 2 au format bluetooth aptx le résultat est étonnant de qualité .Pas de souffle,ouverture et dynamique au rdv.A conseiller sans réserve.
PS:le reste du systeme :ampli a tube Jadis et enceintes Diy pavillon arriere large bande FOSTEX.
This review has been posted for Roxa Stereo Audio Receiver Bluetooth 4.0 aptX + Charger 1A
