Bluetooth 5.0 Receiver CSR8675 ES9218P aptX HD LDAC LHDC
Shanling's BA1 is a desktop Bluetooth 5.0 receiver. It is equipped with a CSR8675 Bluetooth receiver chip, an ESS ES9218P digital/analog conversion chip and is particularly easy and convenient to use.
BA1's digital/analog conversion stage is equipped with an ESS ES9218P DAC chip. This one allows to provide a sound reproduction of quality, in particular thanks to a very low level of distortion.
Thanks to its Qualcomm CSR8675 chip, the BA1 supports Bluetooth 5.0, allowing you to stream your audio files simply and remotely. This chip supports high-resolution Bluetooth codecs such as HWA, aptX, aptX HD, aptX LL and LDAC, allowing you to enjoy your high-quality audio files.
Thanks to its dedicated control application, the Shanling BA1 offers advanced settings such as access to digital filters, equalizer and channel balance management.
The Shanling BA1 can also connect directly to your computer via USB, in order to use it as an external USB DAC. Installation is extremely simple and requires no driver installation.
The BA1 benefits from 3 different outputs to adapt to each user's audio system. There is a 3.5mm headphone output, a stereo RCA output and a Toslink optical output.
Product type | Bluetooth receiver |
Bluetooth reception chip | Qualcomm CSR8675 |
DAC Chip | ESS ES9218P |
Bluetooth version | 5.0 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, aptX LL, LDAC, LHDC |
Inputs | Bluetooth 5.0 1x USB-C |
Output | 1x Jack 3.5mm headphone output 1x Stereo RCA 1x Optical Toslink |
Supported sampling rates | Bluetooth (LDAC / LHDC) : PCM up to 24bit 96kHz USB DAC: PCM up to 16bit 48kHz |
Transmission distance | 10m |
Output level | Headphone output: 1.41V RCA : 2V |
SNR | -115dB |
Channel separation | 73dB |
THD | 0.0085% |
Power supply | 5V 1A via USB-C (power supply not included) |
Dimensions | 128 x 100 x 26mm |
Weight | 205g |
Color | Black |
Input | Bluetooth |
Input | USB |
Output | RCA |
Output | Optical Toslink |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9218P |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | LDAC |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | HWA LHDC |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
