Tour de cou malin, pratique et efficace. Marié avec des intras tinfi P1exigeant en terme de puissance, la bête s'en sort correctement.
Bluetooth 5.0 Receiver DAC Headphone Amplifier AK4377 CSR8675 MMCX
The Shanling MW200 is a Bluetooth receiver, DAC and headphone amplifier in neckband format. It benefits from a very nice design quality to offer you a great sound quality. It has a MMCX connector to connect your headphones or your earphones. The MW200 will allow you to simply broadcast your music from your smartphone or tablet to the receiver. Thus, no need for a cable to make the link between your headphones and your playback device.
The conversion and amplification stage of the MW200 uses an AKM AK4377 chip. It offers an excellent sound reproduction, marked by a magnificent precision and a great richness of the audio message.
The Bluetooth 5.0 reception of the MW200 is provided by a Qualcomm CSR8675 chip. This allows a stable reception of the signal. It is also compatible with the standard Bluetooth codecs SBC and AAC, but also with aptX HD/LL, LDAC and HWA LHDC. These last codecs allow a transmission of very high quality without delay, up to 24bit 96kHz for the LHDC.
The cabling of the MW200 is optimized, integrating high purity OFC copper conductors with silver plating, ensuring a perfect conductivity.
The MMCX connectors of the MW200 benefit from an excellent quality, with a gold plating for a good signal transmission but also an excellent resistance to oxidation.
The MW200 also has a good autonomy, with a continuous use in reading of 14 hours or 500 hours in standby. It also integrates the Quick Charge technology: only 10 minutes are enough for a use during 2 hours.
With its IPX4 rating, the MW200 is resistant to splashing water and humidity.
Pairing the Shaling MW200 to your smartphone can be done quickly and easily. Using the NFC protocol, all you have to do is bring the receiver close to your smartphone to pair it up.
The MW200 also features a high-quality Knowles microphone with cVc Noise Cancellation technology and the One-Click Assistant tool.
An LED indicator on the MW200 makes it easy to see which Bluetooth codec is being used to transmit the signal:
The MW200 comes with a mobile application available on Android and iOS, allowing access to many parameters to adapt the sound reproduction to your listening: digital filters, balance, equalizer... all this can be controlled simply from your smartphone.
With the Shanling Controller App, you can also update the MW200 to the latest firmware with one click.
OTA updates are only available for Android devices.
Product type | Bluetooth receiver DAC Headphone amplifier |
DAC / Headphone amplifier chip | AKM AK4377A |
Bluetooth chip | Qualcomm CSR8675 |
Bluetooth version | 5.0 |
Supported codecs | LDAC, HWA LHDC, aptX HD, aptX LL, AAC, SBC |
Power | 27mW @ 32Ω |
SNR | 119dB |
Connectors | MMCX |
Cable conductors | Silver plated Copper |
Microphone brand | Knowles |
Water resistance rating | IPX4 |
Battery capacity | 360mAh |
Autonomy in operation | Up to 14h (SBC) Up to 11h (LDAC) |
Standby autonomy | Up to 500h |
Charging | Via USB-C |
Neckband material | Silicon |
NFC Pairing | |
Mobile app | Android, iOS |
OTA Updates | |
USB DAC Function | Up to 16bit 48kHz |
Input | Bluetooth |
Output | MMCX |
DAC / ADC Chip | AK4377 |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | LDAC |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | HWA LHDC |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean-Charles g.
