SMSL B1 Audio Receiver Bluetooth 4.2 aptX NFC DAC WM8524 24Bit/192kHz
4.9 / 5
Reference : 11444
64,90 €tax incl.
54,08 € tax excl.
The SMSL B1 Bluetooth Audio receiver features AptX technology and allows you to enjoy high-quality wireless on your devices that do not have this basic feature. Thanks to its technology Bluetooth 4.2 aptX, there is no delay and audio delay on the devices aptX Certified Low Latency .
The SMSL B1 is equipped with a DAC Wolfson WM8524, decoding streams up to 24Bit / 192kHz. It also has a Headphone amplifier MAX97220Adriving headphones up to 32 Ohm / 65mW via its 3.5mm jack output.
Its outputRCA Stereo , and its two digital outputs Optical/Coaxialallow you a wide choice of connection to your HiFi and Home Cinema devices.
One of the special features of this Bluetooth SMSL receiver is its ability to run on battery. The latter with a capacity of 800mAh allows you to last for 12 hours in operation. It is of course possible to let it plug in permanently.
The volume button allows you toHeadphones. Theoutputs RCAthey remain fixed.
Qobuzissime won by SMSL B1
Discover the complete and detailed test of the SMSL B1 Bluetooth receiver, which has been awarded a Qobuzissime for its qualities and performance (Click on the banner below).
Qobuzissime SMSL B1
General specifications:
  • Bluetooth version: 4.2 aptX (NFC Compatibility)
  • Optical and Coaxial Sampling Rate: Up to 48kHz
  • Charging voltage: 5V (AC adapter available in accesries)
  • RCA Output Level: 1.8V rms
  • Battery capacity: 800mAh
  • Power consumption: 120mW
  • Digital receiver: CS8406 (PDF available in the attached files below)
Features DAC:
  • DAC Wolfson: WM8524 24Bit / 192kHz (PDF available in the attached files below)
  • Dynamic range: 95dB
  • Noise Ratio: 96dB
  • THD + N: 0.02%
Features Headphone Amplifier:
  • Chipset: MAX97220A (PDF available in attached files below)
  • Noise Ratio: 96dB
  • THD + N: 0.03%
  • Output: 32 Ohm / 65mW (@ THD + N 0.01%)
Connectivity / Dimensions / Weight:
  • Input Micro USB (For power or charge)
  • Outputs: RCA Stereo / Optical / Coaxial
  • Headphones Jack 3.5mm
  • Dimensions: 70x81x25mm
  • Weight: 158g
  • Black color
  • Comes with: Micro-USB to USB-A cable / Bluetooth antenna
Caractéristiques SMSL B1
OutputJack 3.5mm
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipWM8524
35 reviews
Très bon récepteur
Je possède ce récepteur depuis 5 ans. Donc a priori fiable. A été branché en optique sur un DAC pour écouter des fichiers flac stockés sur mon mobile. Très bonne restitution. Actuellement raccordé via les RCA analogiques sur un Cyrus 8 vs2. Différence inaudible par rapport au lecteur cd Cyrus 8. Sa batterie intégré permet de le brancher rapidement sur n'importe quel ampli pour faire des tests ou écouter sa musique sur d'autres installations.
This review has been posted for SMSL B1 Audio Receiver Bluetooth 4.2 aptX NFC DAC WM8524 24Bit/192kHz
Impeccable
Commandé le jeudi reçu la samedi :)
Ce petit boitier fait parfaitement le job, je l'ai connecté sur l'entrée spdif du lecteur Audia CD1M, la restitution est excellente au regard de l'investissement ! Mon installation B&W 805d2 DB2d - Fls9 - Cd1M
Récepteur audio bluetooth
Produit conforme mes attentes très bon son sur chaîne hifi ainsi qu'une très bonne transaction
Minuscule
A l'ouverture de la boîte on est surpris par la petite taille de l'appareil, il est vraiment minuscule! La qualité de fabrication est pourtant bien là. Cependant, pas la moindre trace d'un quelconque mode d'emploi. Il n'y a pas non plus de chargeur, seul un câble USB permet de raccorder une alimentation en provenance d'un port USB. L'appairage bluetooth se fait en posant le téléphone sur le boîtier, après avoir pris la précaution de mettre sur ON la fonction NFC du téléphone. Procédé extrêmement simple et rapide. Le son est parfait, un autre bon point est la rétrocompatibilité avec des appareils non équipés de codec aptX dernière génération. L'ampli casque est moyen.
En résumé, bon appareil, pratique. Tout a fait recommandable.
Que du bon voir du très bon !!!
Petite boite magique ! elle est petite ,mignonne ,très bien finie et d'un tarif raisonnable. Le branchement se fait sans problème en bluetooth et je choisis mon meilleur cable coaxial et j'envoi .Ouf
le choc !!! le son provenant de mon portable sur ma chaine hifi est excellent voir meilleur qu'avec mon lecteur cd . Une vrai réussite et merci à Audiophonics
