TALENT MC3 Portable audio transmitter for Silent disco UHF/RF headphones
This portable audio transmitter has been specially designed to work with Audio Talent Silent Disco headphones. The transmitter's form factor is ideal for portable applications. It's perfect, for example, if you need to transmit a signal while on the move, as tour guides do.
By buying this product you get 33 loyalty points
Reference : 18815
339,00 €tax incl.
282,50 € tax excl.
This product is temporarily unavailable.
TALENT MC3Portable audio transmitter for Silent disco UHF/RF headphones
Photo of Talent MC3 transmitter
This portable audio transmitter has been specially designed to work with Audio Talent Silent Disco headphones. The transmitter's form factor is ideal for portable applications. It's perfect, for example, if you need to transmit a signal while on the move, as tour guides do. Here are the main highlights of this audio transmitter:
  • Up to 3 transmitters can be combined to create a 3-channel environment where the user can choose the source via his Talent Silent Disco headphones.
  • This transmitter can be paired with an unlimited number of headphones.
  • The UHF/RF system offers a range of 100m.
  • The transmitter features two inputs, including a microphone input, as well as Bluetooth.
TALENT MC3 audio transmitter: dual-input design
The Talent MC3 features a 3.5mm jack aux input and a 3.5mm jack microphone input. Added to this is Bluetooth functionality, enabling you to set up a completely wireless transmission system. A microphone is supplied with the MC3 audio transmitter.
Talent MC3 transmitter inputs
Talent MC3 transmitter range
TALENT MC3 audio transmitter: extended range
The Talent MC3 audio transmitter's FM modulation transmission extends over a range of almost 100m, covering the entire area of your event or activity.
TALENT MC3 audio transmitter: a sturdy, practical carrying case
The MC3 audio transmitter comes with a carrying case specially designed to carry all the transmitter's components, including a charger and microphone.
Audio Talent MC3 transmitter in carrying case
Product typePortable audio transmitter for Talent Silent Disco headphones
Pairing numberUnlimited
Operating frequencyUHF/RF (914-915 MHz)
ModulationFM
ModeStereo
Inputs1x AUX input 3.5mm jack
1x 3.5mm microphone input
Bluetooth
Frequency response30Hz-20KHz
Operating distance100m (High)
50m (Low)
Distorsion< 1%
Channel separation>50 dB
Antenna height17cm
Power supply12V 1.3A DC
Dimensions127 x 11.4 x 3.8mm
Package1x TALENT MC3 audio transmitter
1x Microphone with integrated 3.5mm jack termination
1x 3.5mm jack to 3.5mm jack cable
1x US mains adapter
1x Storage/transport case
InputJack 3.5mm
OutputModulation FM
DAC / ADC ChipNC
Transmission / Reception protocolUHF/RF
Supported Bluetooth codecsN/A
This portable audio transmitter has been specially designed to work with Audio Talent Silent Disco headphones. The transmitter's form factor...
