TINYSINE BT-TX Bluetooth Plug & Play Transmitter A2DP
This BT-TX from TinySiny will allow you to transform your Bluetooth-free music source into a transmitter. This eliminates the need for cables to send music from your source to your Bluetooth amplifier.
2.0 / 5
Reference : 12875
15,90 €tax incl.
13,25 € tax excl.
TinySine BT-TX
Bluetooth Transmitter Plug & Play A2DP
TinySine BT-TX émetteur bluetooth plug & play a2dp
This BT-TX from TinySiny will allow you to transform your Bluetooth-free music source into a transmitter. This eliminates the need for cables to send music from your source to your Bluetooth amplifier. In addition, it is equipped with a battery with an autonomy of 5-7 hours for use without power supply. Of course, it is still possible to power the unit with the supplied DC/USB Jack cable for extended use.
Installation is very simple. The device does not require the installation of any driver. Simply connect the 3.5mm Jack to your source. Then all you have to do is press the button for 3 to 5 seconds to turn on the transmitter.
Warning: It is necessary that your receiving device is Bluetooth A2DP compatible.
Pairing the TinySine BT-TX
The first time you use the BT-TX with a device you will need to pair these. Here is the process:
  1. Set your BT-TX Bluetooth transmitter and Bluetooth receiver to a maximum of 5m for pairing time.
  2. Turn on your Bluetooth receiving device and set it to pairing mode.
  3. Turn on your BT-TX Bluetooth transmitter and press the main button for 6-7 seconds. When the blue and red LEDs start flashing alternately, the transmitter is in pairing mode. It will then automatically search for the receiver, pair with it and connect to it.
  4. Once connected, the blue LED will flash twice in 4 seconds.
  5. Connect the cable to your music source. Now you can enjoy your music wirelessly.
Bluetooth version2.1+EDR
Bluetooth ProfileA2DP
InputJack 3.5mm
Battery autonomy6-7 hours
Charging time1.5 hours
Dimensions45 x 32 x 8mm
Weight14g
Package1x TinySine BT-TX
1x USB-A to Jack DC Cable
InputJack 3.5mm
OutputBluetooth
DAC / ADC ChipNC
Supported Bluetooth codecsN/A
2 reviews
appairage
très déçu par le produit : impossible de l'appairer avec mon casque JBL et votre service technique n'a pas la solution
Bonjour,
Si le module s'appaire normalement avec d'autres produits ce n'est pas lui le problème.
Le protocole est le même quel que soit la marque ou le constructeur.
This review has been posted for TINYSINE BT-TX Bluetooth Plug & Play Transmitter A2DP
Très satisfaisant
Satisfaisant à quelques mètres (je n'avais pas besoin de plus), appairage rapide, signal propre à condition de fournir un niveau BF suffisant (sortie casque par exemple).
This BT-TX from TinySiny will allow you to transform your Bluetooth-free music source into a transmitter. This eliminates the need for cables to...
