USB Dongle Bluetooth 5.2 Transmitter aptX / aptX HD / aptX LL / aptX Adaptive
This Bluetooth 5.2 USB transmitter dongle will allow you to broadcast audio streams wirelessly, from a computer for example, and in high quality, thanks to the use of a Qualcomm QCC3040 Bluetooth chip. This one is indeed compatible with the codecs of high resolution transmission aptX, aptX HD, aptX LL and aptX Adaptive, for a sound quality equivalent or even superior to that of the CD.
Reference : 16693
19,90 €tax incl.
16,58 € tax excl.
Bluetooth 5.2 transmitter dongle
Dongle Émetteur Bluetooth 5.2 aptX / aptX HD / aptX LL / aptX Adaptive
This Bluetooth 5.2 USB transmitter dongle will allow you to broadcast audio streams wirelessly, from a computer for example, and in high quality, thanks to the use of a Qualcomm QCC3040 Bluetooth chip. This one is indeed compatible with the codecs of high resolution transmission aptX, aptX HD, aptX LL and aptX Adaptive, for a sound quality equivalent or even superior to that of the CD. A small LED on the dongle indicates the audio codec used by the dongle:
  • SBC : Fixed blue
  • aptX : Flashing green
  • aptX HD : Fixed green
  • aptX LL : Flashing red
  • aptX Adaptive : Fixed red
Product typeBluetooth transmitter dongle
Bluetooth version5.2
Transmission range15m (maximum without obstacles)
Frequency range2.402-2.480GHz
Transmission protocolsA2DP
AVRCP
HFP
HSP
Supported Bluetooth codecsSBC, aptX, aptX HD, aptX LL, aptX Adaptive
CompatibilityWindows XP / 7 / 8 / 10
Linux
Android
PS4 / PS5
Nintendo Switch
Number of devices that can be connected simultaneously1
Input
  • USB
Output
  • Bluetooth
DAC / ADC Chip
  • NC
Color
  • Black
Transmission / Reception protocol
  • Bluetooth
  • aptX
  • aptX Adaptive
  • aptX HD
  • aptX LL
  • SBC
3 reviews
Dongle
Ce dongle est performant sur W11. La connexion reste stable sur les 4 mètres qui le séparent de mon ampli.
Il privilégie le protocole APTX HD au maximum, car mon récepteur Bluetooth sur l'ampli ne peut pas accepter l'APTX Adaptive mais accepterait le LDAC.
AUDIOPHONICS devrait ajouter un dongle LDAC au catalogue .
Mais bon, mes FLAC restent très largement "écoutable"
This review has been posted for USB Dongle Bluetooth 5.2 Transmitter aptX / aptX HD / aptX LL / aptX Adaptive
Acheté pour utilisation arec une tablette sous W10 dont le Bluetooth a rendu l'âme. Reconnu directement et facile à connecter après quelques clignotements sur un D50s. Le son est plus que correct avec un léger assombrissement facile à corriger dans Foobar2000 (equaliser).
Excellent RQP.
Fonctionne très bien
Rien de particulier à dire sur ce dongle qui fonctionne sur mon PC en windows 10.
This Bluetooth 5.2 USB transmitter dongle will allow you to broadcast audio streams wirelessly, from a computer for example, and in high quality,...
