Un résultat Audio très satisfaisant, toutes les sorties utiles dispo ! Une rareté sur le marché...
On aurait apprécié une entrée AES-EBU, mais la perfection n'est pas de ce monde :)
Récepteur Bluetooth 5.1 aptX HD LDAC DAC 2x ES9018K2M 24bit 96kHz
The MU-605 from xDuoo is a Bluetooth 5.1 receiver, allowing you to offer to your classic HiFi system the capacity of a wireless reception and thus the possibility for you to broadcast your music from your smartphone or tablet. It also supports the high-resolution audio codecs aptX, aptX LL, aptX HD and LDAC, capable of providing a sound quality similar or even superior to that of CD.
Moreover, the conversion of the signal from digital to analog is entrusted to two ESS ES9018K2M DAC chips, offering very good audio performance with high SNR and very low THD+N, for a detailed and clear reproduction.
On the output side, the MU-605 offers a complete range of connectors, allowing it to be easily integrated into the majority of audio systems. On the digital side, we find coaxial, Toslink optical and AES/EBU. On the analog side, the device adds single-ended RCA and balanced XLR.
| Specifications | |
| Product type | Bluetooth receiver |
| Input | Bluetooth 5.1 |
| Outputs | 1x Optical Toslink 1x Coaxial 1x AES/EBU 1x Single-ended sterep RCA 1x Balanced stereo XLR |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX LL, aptX HD, LDAC |
| Transmission range | 10m (barrier free) |
| Output level | Optical : 0.5Vp-p Coaxial : 0.5Vp-p AES : 1Vp-p RCA (AUX) : 2V XLR : 4V |
| THD+N | Optical : 0.0003% Coaxial : 0.005% AES : 0.003% RCA (AUX) : 0.005% @ 1kHz XLR : 0.003% @ 1kHz |
| SNR | RCA (AUX) : 110dB XLR : 120dB |
| Crosstalk | RCA (AUX) : 108dB XLR : 110dB |
| General | |
| Supply voltage | 12VDC 2A |
| Dimensions | 120 x 78 x 40mm |
| Weight | 350g |
| Color | Gray |
| Package | 1x xDuoo MU-605 1x Power supply 1x Bluetooth antenna |
| Input | Bluetooth |
| Output | Optical Toslink |
| Output | XLR |
| Output | AES/EBU |
| Output | RCA |
| Output | Coaxial SPDIF |
| DAC / ADC Chip | ES9018K2M |
| Color | Gray |
| Transmission / Reception protocol | Bluetooth |
| Supported Bluetooth codecs | AAC |
| Supported Bluetooth codecs | aptX HD |
| Supported Bluetooth codecs | LDAC |
| Supported Bluetooth codecs | SBC |
| Supported Bluetooth codecs | aptX |
| Supported Bluetooth codecs | aptX LL |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Philippe P.
Nicolas P.
