XDUOO MX-01 Bluetooth 5.3 Transmitter
xDuoo's MX-01 is a high-performance Bluetooth 5.3 transmitter. It incorporates a Qualcomm chip, a guarantee of stability and quality. The MX-01 is capable of transmitting high-resolution codecs such as SBC, AAC, aptX, aptX LL, adaptive aptX and aptX HD. It features two antennas for a transmission range of up to 100m in unobstructed environments.
4.3 / 5
Reference : 18752
84,90 €tax incl.
70,75 € tax excl.
XDUOO MX-01 Bluetooth 5.3 transmitter AptX LL aptX Adaptive aptX HD
Xduoo MX-01 picture
xDuoo's MX-01 is a high-performance Bluetooth 5.3 transmitter. It incorporates a Qualcomm chip, a guarantee of stability and quality. The MX-01 is capable of transmitting high-resolution codecs such as SBC, AAC, aptX, aptX LL, adaptive aptX and aptX HD. It features two antennas for a transmission range of up to 100m in unobstructed environments. It also features numerous inputs: AUX RCA input, SPDIF coaxial input, Toslink optical input, USB-C input. This means you can connect a wide range of sources, from your TV and CD player to your computer, and broadcast your audio signal to your Bluetooth speakers or wireless headphones.
XDUOO MX-01 Bluetooth transmitter overview
Xduoo MX-01 overview
12x Bluetooth transmission antenna
2AUX RCA input
3SPDIF coaxial input
4Toslink optical input
5USB-C input
6USB-C power supply port
Product typeBluetooth transmitter
Inputs1x AUX input on RCA connectors
1x SPDIF coaxial input
1x Toslink optical input
1x USB-C input
Bluetooth version5.3
Codecs Bluetooth supportésSBC, AAC, aptX, aptX LL, aptX Adaptive, aptX HD
Power supply5V DC 1A via USB-C
Dimensions120 x 75 x 40mm
Net weight320g
Package1x Bluetooth transmitter xDuoo MX-01
OutputBluetooth
DAC / ADC ChipNC
ColorBlue
Supported Bluetooth codecsAAC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsSBC
3 reviews
Transmetteur utilisé en émetteur (de mon ampli vers un casque B&W)
Appairage un peu difficile : bien penser à éteindre / couper les appareils BT à proximité SAUF le casque (dans mon cas).
En effet, il est impossible de savoir avec qui le MX-01 est appairé !
Sinon, fonctionne sans problème
This review has been posted for XDUOO MX-01 Bluetooth 5.3 Transmitter aptX Adaptive
Le premier transmetteur reçu était défectueux et j'ai dû le renvoyer, mais Audiophonics l'a vite remplacé et m'avais bien tenu au courant du traitement de ma réclamation. Le nouveau transmetteur a bien fonctionné tout de suite. L'installation était fait dans 5 minutes. 4 étoiles pour xduoo, 5 étoiles pour Audiophonics.
Excellent product.
High quality product. The Bluetooth connections with it are very fast, without any break and with a big range. Very small form factor. It's a pity that Xduoo doesn't send the power supply, but any usb charger do the trick. I don't know why Xduoo designed this product without a remote control, it's a pity.
xDuoo's MX-01 is a high-performance Bluetooth 5.3 transmitter. It incorporates a Qualcomm chip, a guarantee of stability and quality. The...
