XDUOO XQ-50 Bluetooth 5.0 Receiver aptX QCC3008 DAC ES9018K2M
xDuoo offers with its XQ-50 a Bluetooth receiver with integrated DAC very practical, qualitative and affordable. It will allow you to stream your music directly from your smartphone, tablet or any other device with Bluetooth connectivity (transmitter). Its careful design allows it to offer a clean playback of your audio files.
Reference : 13929
54,90 €tax incl.
45,75 € tax excl.
This product has been replaced by the new version, the XDUOO XQ-50s Bluetooth receiver 5.1 QCC3034.
xDuoo XQ-50
Bluetooth 5.0 Receiver aptX CS8406 DAC ES9018K2M
xDuoo XQ-50 Récepteur Bluetooth 5.0 aptX CS8406 DAC ES9018K2M 16bit 44kHzxDuoo XQ-50 Récepteur Bluetooth 5.0 aptX CS8406 DAC ES9018K2M 16bit 44kH
Bluetooth 5.0 & aptX
The XQ-50 is equipped with a Qualcomm QCC3008 Bluetooth receiver chip. It supports Bluetooth 5.0 and the aptX transmission protocol. This protocol ensures fast and stable data transmission and guarantees high quality Bluetooth audio playback. A Bluetooth antenna improves the maximum transmission distance.
DAC ES9018K2M
The receiver is also equipped with a DAC ESS ES9018K2M chip for digital-to-analog conversion. This chip helps to provide an accurate and most accurate reproduction possible.
SPDIF CS8406 aptX
The output panel has a RCA stereo analog connector, a digitial S/PDIF and a Toslink connector. The digital output stage uses a SPDIF CS8406 interface chip. The device can also function as a USB DAC by connecting it directly via its USB-C port to a computer.
Product typeBluetooth receiver
Bluetooth version5.0
Supported bluetooth protocolsSBC, AAC, aptX
Bluetooth chipQCC3008
Digital interfaceCS8406
DAC ChipES9018K2M
Transmission distance10m
THD+NCoaxial, Optical: 0.00087%
Stereo RCA : 0.07%
Output levelCoaxial, Optical: 0.5Vp-p
Stereo RCA : 2.5V
Supported sampling rateUp to 16bit 44kHz
Power supply5VDC 1A via USB-C (5V USB-C adapter available)
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
3 reviews
Manifestement un bon produit
Facile à installer (en RCA stéréo sur le vieil equalizer associé à mon ampli Yamaha). Connexion très stable depuis mon PC, même à plusieurs mètres avec des obstacles occultant complètement l'angle de vue. Une led "HD" s'allume quand le codex aptX est utilisé. Finition flatteuse. Quant à la qualité du son, je ne peux guère en juger, les sources que j'utilise n'étant en général pas très bonnes.
This review has been posted for XDUOO XQ-50 Bluetooth 5.0 Receiver aptX QCC3008 DAC ES9018K2M
Impressed
I just connected the XQ-50 to my Pro-Ject Stereo Box S2 via Merlin Mozart cables, and it sounds impressively good (aptx, 320k mp3). Clear and extended, with a sense of 'airy' sound. I'm only considering later replacing the JRC 5532DD with a LT1358 for an even richer and smoother sound.
Un bon produit
Conforme au descriptif, connexion Bluetooth parfaite et de très bonne qualités audio, grave présent, boitier très discret, supérieur au FX-AUDIO BL-MUSE-03.
xDuoo offers with its XQ-50 a Bluetooth receiver with integrated DAC very practical, qualitative and affordable. It will allow you to stream your...
