XDUOO XQ-50 PRO2 Bluetooth 5.1 Receiver QCC5125 aptX HD LDAC DAC ES9018K2M
xDuoo offers with its XQ-50 Pro2 an excellent Bluetooth receiver, easy to use and powerful, which will allow you to transform your audio installation into a wireless system. It becomes possible to broadcast your music remotely, directly from your smartphone, tablet or any other connected device.
4.7 / 5
Reference : 15783
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 06-05-2025.
xDuoo XQ-50 Pro2
xDuoo XQ-50 Pro2 Récepteur Bluetooth 5.1 QCC5125 aptX HD LDAC DAC ES9018K2M
The XD-50 Pro2 uses a highly efficient Qualcomm QCC5125 Bluetooth 5.1 receiver chip that supports the high-resolution codecs aptX, aptX HD and LDAC. These allow you to enjoy excellent sound quality when transmitting your music via Bluetooth. The digital / analog conversion is provided by an independent chip, a DAC ESS ES9018K2M, for a precise sound reproduction.
The front panel of the receiver has a 1.3" OLED screen, displaying all the information concerning the playback of your files: Bluetooth codec used, sampling rate of the file or even the title of the song.
Finally, the XQ-50 Pro2 can be connected via USB-C to a computer. In this case it can work as a USB DAC.
Test of the XQ-50 PRO 2 by Audio Science Review
"The XQ-50 Pro2 might have better performance, but it's still a good performer. It's a very good device coupled with a DAC, as its Bluetooth performance with high-definition codecs delivers a level of sound quality close to a wired system."
Logo Audio Science Review
Product typeBluetooth receiver
Bluetooth version5.1
Bluetooth chipQCC5125
ÎnputsBluetooth 5.1
1x USB-C
Outputs1x Stereo RCA
1x Coaxial
1x Optical Toslink
Supported Bluetooth codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
THD+NOptical : 0.00087%
Coaxial : 0.00087%
RCA : 0.07%
Output levelOptical : 0.5Vp-p
Coaxial : 0.5Vp-p
RCA : 2V
Supply voltage5V 1A
Housing materialAluminum
Dimensions105 x 76 x 34mm
Weight165g
Package1x USB-A to USB-C cable
1x Bluetooth antenna
Input
  • Bluetooth
  • USB
Output
  • Coaxial SPDIF
  • Optical Toslink
  • RCA
DAC / ADC Chip
  • ES9018K2M
Color
  • Black
Transmission / Reception protocol
  • Bluetooth
  • AAC
  • aptX
  • aptX HD
  • aptX LL
  • LDAC
  • SBC
9 reviews
Ravi
Ravi de ce petit récepteur qui me permet de transmettre le son maigrichon d'un smartphone Redmi 13C (un seul haut parleur !...) à un vieil ampli analogique Pioneer : réception en LDAC, pas de coupure son même en promenant le téléphone d'une pièce à l'autre, et un son transmuté. Ne pas hésiter à relier les deux appareils avec un câble RCA de qualité, donc.
This review has been posted for XDUOO XQ-50 PRO2 Bluetooth 5.1 Receiver QCC5125 aptX HD LDAC DAC ES9018K2M
OK but not more
The receiver works well, but the sound quality is just ok
Je recommande
Joli boitier, très bien fini... bien supérieur à des boitiers du même type (1MII, IFI audio...).
Connection immédiate à mon smartphone (pourtant pas très récent) - Codec bluetooth LDAC (en série sur tout smartphone depuis android 8.0). Le son en sortie coax et avec le LDAC est vraiment d'une qualité qui n'a rien à voir avec le sbc, on est vraiment qualité CD et à l'oreille pas de différence en sortie de mon ampli - dac avec mon lecteur cd hifi.
Sortie RCA, signal interprété par le dac intégré, semble tout à fait honorable peut être un peu moins d'ampleur que mon dac hifi mais je ne peux rien affirmer, car pas assez de temps d'écoute...
Pour le prix je suis ravi de pouvoir simplement et sans réseau, véhiculer de la musique sans fil avec une qualité plus que correcte. J'avais peur de la qualité Bluetooth qui ne m'a jamais vraiment séduit mais les codec LDAC, apt-x lossles ou LHDC remettent les pendules à l'heure. Le LDAC et LHDC largement intégrés sur smartphones sont vraiment équivalent au CD si notre fichier source est lui-même correct (Flac...)
like: Easy to use. Excellent specifications.
dislike: No secure pairing.
LDAC is good
Good receiver, takes highest BT LDAC settings to optical out without any problem. Seems bigger on the picture, but in reality is nice small sized. Did not need or test other settings.
xDuoo offers with its XQ-50 Pro2 an excellent Bluetooth receiver, easy to use and powerful, which will allow you to transform your audio...
