XDUOO XQ-50s Bluetooth 5.1 Receiver QCC3034 ES9018K2M aptX-HD
The xDuoo XQ-50s Bluetooth 5.1 Receiver is the perfect ally to give an existing audio system wireless reception functionality and allow you to stream your music remotely, directly from a smartphone or tablet. The XQ-50s uses a high-performance Qualcomm QCC3034 receiver chip, ensuring stable audio signal transmission.
2.5 / 5
Reference : 15772
54,90 €tax incl.
45,75 € tax excl.
xDuoo XQ-50s
xDuoo XQ-50s récepteur Bluetooth 5.1 QCC3034 ES9018K2M aptX-HD
The xDuoo XQ-50s Bluetooth 5.1 Receiver is the perfect ally to give an existing audio system wireless reception functionality and allow you to stream your music remotely, directly from a smartphone or tablet. The XQ-50s uses a high-performance Qualcomm QCC3034 receiver chip, ensuring stable audio signal transmission. What's more, this chip supports the aptX / aptX-HD codecs and allows you to connect two devices at once. This chip is directly associated with a DAC ES9018K2M, allowing to convert the digital signal into analog. Finally, the XQ-50s can function as a USB DAC by connecting it directly to a computer.
Product typeBluetooth receiver
1x USB-C
Outputs
1x Stereo RCA
1x Coaxial
1x Optical Toslink
Bluetooth version5.1
Bluetooth chipQCC3034
DAC chipES9018K2M
Max. transmission distance≈10m
THD+NOptical / Coaxial : 0.00087%
AUX out : 0.07%
Output levelOptical / Coaxial : 0.5Vp-p
AUX out : 2V
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD
Supply voltage5VDC 1A
Dimensions (without antenna)76 x 105.5 x 34mm
Weight166g
Housing materialAluminum
Package1x xDuoo XQ-50s
1x Antenne Bluetooth
1x Câble d'alimentation USB
OutputCoaxial SPDIF
OutputOptical Toslink
DAC / ADC ChipES9018K2M
2 reviews
Top mais...
La puce à l'intérieur est bien une QCC3031 et non une ACC3034.
Le site de Qualcomm se trompe peut-être sur les spécifications de ses puces (...) par contre Xduoo et Audiophonics trompent leurs clients sur ce qui leurs est vendu (photo de la carte du XQ-50s à l'appui) et ça je trouve que c'est moyen.
Le produit reste de bonne facture.
This review has been posted for XDUOO XQ-50s Bluetooth 5.1 Receiver QCC3034 ES9018K2M aptX-HD
Top mais...
Fonctionnement facile, fabrication de qualité.
Une étoile en moins pour le marketing mytho à la chinoise : il s'agit bien du XQ-50 en bluetooth 5.0 re-nommé XQ-50s (mais sans le bluetooth 5.1).
The xDuoo XQ-50s Bluetooth 5.1 Receiver is the perfect ally to give an existing audio system wireless reception functionality and allow you to...
