MUNDORF BS180 ICORE Copper Coil Feron Core Ø1.8mm 1.2mH
The Mundorf BS180 coils are high performance coils, ideal for midrange crossovers in subwoofers. The core is made of Feron, which underwent a heat treatment after its production.
Reference : 15213
34,90 €tax incl.
29,08 € tax excl.
Mundorf Mcoil BS180 Icore
Copper Coil Feron Core 1.2mH
Mundorf Mcoil BS180 Icore Bobine Cuivre Noyau Feron 1.2mH
The Mundorf BS180 coils are high performance coils, ideal for midrange crossovers in subwoofers. The core is made of Feron, which underwent a heat treatment after its production. This treatment gives it an optimal internal structure for good magnetic characteristics offering very low losses and low distortion. Their power handling is also higher than for conventional ferrite core coils. The "Backed Varnish" finish allows to limit vibrations and to use a maximum wire diameter for a reduced electrical resistance.
Product typeCoil
MaterialOFC Copper
CoreiCore Feron
Inductivity1.2mH
DC Resistance0.07 Ohm
Section2.55mm² (13AWG) | 1.8mm
Dimensions106 x 33 x 33mm
Inductance (mh)1.2
The Mundorf BS180 coils are high performance coils, ideal for midrange crossovers in subwoofers. The core is made of Feron, which underwent a heat...
