HIFI 2000 Case 4U 300mm - Front 4mm Silver
Reference : 1348
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 25-04-2025.
HIFI 2000
Housing 430 x 300 x 165 Front cover 4 mm Silver
1PS04PB Boitier HiFi2000
This casing benefits from a superior manufacture quality and design it exist in many different sizes and can therefore be used in any kind of project : prototyping, repairing, upgrading, merging existing devices...etc.The edges are smoothed in order to let you work and move freely and safely the housing.
The rear face already has hole for an IEC socket. Top and bottom cover are treated with an anti-sratch paint for a long-lasting brand-new look.
Internal dimensions
DimensionsHeightWidthDepth
Internal165430300
External167435305
Parts
TypeSelf-Assembly housing
Front faceAluminum
4mm thick
Face arrièreSteel (anti-scratch paint)
1mm thick
Pre-drilled
CotésSteel (anti-scratch paint)
1mm thick
CapotSteel (anti-scratch paint)
1mm thick
Weight5 kg
ColorSilver
MaterialAluminium
Internal width430
Internal depth300
Internal height165
2 reviews
Decent sturdy chassis for big amps
This is a perfect low cost/ high quality DIY chassis for big projects, if you are using amp modules that have already the PCB mounted onto the heatsinks. Internal volume for 4U- 300mm/400mm depth is so big, that you could build a 5+1 amplifier inside easily by using ready heat-sinked modules. I was using it to re-box an Anthem 225 amplifier, and all the elements has space to cool inside. I was using the spare top
'HIFI 2000 Perforated housing cover 19 "300mm' to allow air circulation.
As the box cannot bear a massive weight on it's own in basic version, my advise is to use this spare bottom: 'HIFI 2000 Inner baseplate 425x260mm (300mm Series)', or to reinforce the chassis base with some L aluminum profiles. It was not my case, as the bottom was reinforced by the 2 massive heat-sinks of Anthem modules. The finish of the 4mm face plate is top notch! Also, the black matte anti-scratch paint of the top/bottom covers is of good quality. The bottom and back-plate steel is easy to process (drilling, milling), as the material does not have a high hardness. Despite the chassis seems to flex without the top cover mounted, when assembled, the whole structure become rock solid! My project weights about 15 Kg, and the box is like a rock-stone once assembled. Highly recommended for tight budget projects.
This review has been posted for HIFI 2000 Case 4U 300mm - Front 4mm Silver
ingénieur-technicien
parfait. très bien fini, et bien emballé
