By buying this product you get 22 loyalty points
Housing 360 x 400 x 80 Front cover 10 mm Black
The 100% aluminum serie is easy to use and to assemble. It has a great capacity to lower thermal stress and to dissipate heat. This casing is an ideal choice for your most ambitious project including professional device making. They are resistant and made 100% from aluminum, thus offering an excellent durability and very light weight.
It has large heatsinks with vertical wings (40mm thick). Moreover, the housing has many holes in its top coper to improve air circulation and preventing overheating. Aluminum as a material plays an important part in heat dissipation.
Specifications | |||
Dimensions | Height | Width | Depth |
Internal | 80 | 360 | 400 |
External | 82 | 440 | 411 |
Parts | |
Type | Self-assembly Housing |
Front cover | Aluminum (Black) 10mm thick |
Back cover | Aluminum (Black) 1mm thick |
Side covers | 4 dissipators 40x200mm Heatsink anodized aluminum |
Top / bottom cover | Aluminum (Black) 1mm thick |
Weight | 5.9 kg |
