HIFI 2000 Heatsink Case 2U 300mm - Front 10mm Black
4.0 / 5
Reference : 1151
155,00 €tax incl.
129,17 € tax excl.
HIFI 2000 with dissipator
Housing 360 x 300 x 80 front face 10 mm Black
1NPD02300N Housing HiFi2000
HIFI 2000 Housing with dissipators are ideal to build HiFi amplifiers or any kind of high-power device. The massive aluminum / steel frame is very sturdy and long-lasting. The HIFI 2000 dissipators series offer different sizes regarding electronic casing. While being versatile enough to be used in a variety of projects, it remains easy to mount and to use.
In addition to large dissipators with vertical wings (40mm), this housing has many opening on its top-plate in order to maximise heat circulation. The materials used in the building process are also very efficient at lowering termal stress.
Internal dimensions
DimensionsHeightWidthDepth
Internal80360300
External82440311
TypeMounting housing
Front coverAluminum
10mm thick
Back coverAnti-scratch Steel
1mm thick
Side covers2 dissipators 40x300mm Anodized aluminum
Top & bottom coversAnti-scratch Steel
1mm thick
Weight5.4 kg
MaterialAluminium
Internal width360
Internal depth300
Internal height80
Produit correct
Boîtier tôle emboutie, avec façade de belle facture en aluminium, montage aisé et intuitif, prix décent. Un seul bémol négatif, faites hyper attention en manipulant le boîtier, les arêtes vives des radiateurs sont aussi coupantes qu'un scalpel... Je vous recommande fortement de ne le manipuler qu'avec des gants (pas en tissus ni en nitrile), sinon mettez les mains sur les façades antérieures, et postérieures.
This review has been posted for HIFI 2000 Heatsink Case 2U 300mm - Front 10mm Black
