HIFI 2000 Heatsink Case 2U 300mm - Front 10mm Silver
This HIFI 200^0 box is particularly suitable for the manufacture of HiFi amplifiers. Its robust design 100% solid aluminium ensures great durability.
4.0 / 5
Reference : 1150
155,00 €tax incl.
129,17 € tax excl.
HIFI 2000 with dissipator
Housing 360 x 300 x 80 front face 10 mm Silver
1NPD02300B Housing HiFi2000
HIFI 2000 Housing with dissipators are ideal to build HiFi amplifiers or any kind of high-power device. The massive aluminum / steel frame is very sturdy and long-lasting. The HIFI 2000 dissipators series offer different sizes regarding electronic casing. While being versatile enough to be used in a variety of projects, it remains easy to mount and to use.
In addition to large dissipators with vertical wings (40mm), this housing has many opening on its top-plate in order to maximise heat circulation. The materials used in the building process are also very efficient at lowering termal stress.
Internal dimensions
DimensionsHeightWidthDepth
Internal80360300
External82440311
TypeMounting housing
Front coverAluminum
10mm thick
Back coverAnti-scratch Steel
1mm thick
Side covers2 dissipators 40x300mm Anodized aluminum
Top & bottom coversAnti-scratch Steel
1mm thick
Weight5.4 kg
ColorSilver
MaterialAluminium
Internal width360
Internal depth300
Internal height120
Beau produit
Beau boîtier de qualité, robuste et bien fini.
Je ne lui attribue pas 5 étoiles car les pieds fournis en plastique low cost ne sont pas au niveau, pas d'amortisseur contre les vibration super léger donc à changer pour autre chose.
La grille pré-percée qui figure sur la dernière photo ne fait pas partie de la livraison, il vous faudra donc percer la tôle de fond pour fixer vos éléments ou trouver où acheter cette grille.
This review has been posted for HIFI 2000 Heatsink Case 2U 300mm - Front 10mm Silver
