HIFI 2000 Heatsink Case 3U 400mm - Front 10mm Black
3.0 / 5
By buying this product you get 20 loyalty points
Reference : 4178
209,00 €tax incl.
174,17 € tax excl.
HIFI 2000 with dissipator
Housing 360 x 400 x 120 front face 10 mm Black
1NPD03400N Housing HiFi2000
HIFI 2000 Housing with dissipators are ideal to build HiFi amplifiers or any kind of high-power device. The massive aluminum / steel frame is very sturdy and long-lasting. The HIFI 2000 dissipators series offer different sizes regarding electronic casing. While being versatile enough to be used in a variety of projects, it remains easy to mount and to use.
In addition to large dissipators with vertical wings (40mm), this housing has many opening on its top-plate in order to maximise heat circulation. The materials used in the building process are also very efficient at lowering termal stress.
Internal dimensions
DimensionsHeightWidthDepth
Internal120360400
External122440411
TypeMounting housing
Front coverAluminum
10mm thick
Back coverAnti-scratch Steel
1mm thick
Side covers4 dissipators 40x200mm Anodized aluminum
Top & bottom coversAnti-scratch Steel
1mm thick
Weight8 kg
MaterialAluminium
Internal width360
Internal depth300
Internal height120
Gets the job done, but that's about it
Looks as described, but it feels cheap. The fact that there are no instructions for assembly, the included feet are the cheapest plastic you can imagine and all of the screws are not labeled, so you have to work it all out for yourself. Not that difficult to put together, but still for this money it should be better.
This review has been posted for HIFI 2000 Heatsink Case 3U 400mm - Front 10mm Black
