This type of housing is particularly suitable for the manufacture of Hi-Fi amplifiers. Steel case with solid aluminium radiators with vertical fins.
By buying this product you get 31 loyalty points
Housing 360 x 500 x 210 front face 10 mm Black
HIFI 2000 Housing with dissipators are ideal to build HiFi amplifiers or any kind of high-power device. The massive aluminum / steel frame is very sturdy and long-lasting. The HIFI 2000 dissipators series offer different sizes regarding electronic casing. While being versatile enough to be used in a variety of projects, it remains easy to mount and to use.
In addition to large dissipators with vertical wings (40mm), this housing has many opening on its top-plate in order to maximise heat circulation. The materials used in the building process are also very efficient at lowering termal stress.
Spécifications | |||
Dimensions | Height | Width | Depth |
Internal | 210 | 360 | 500 |
External | 212 | 440 | 511 |
Type | Mounting housing |
Front cover | Aluminum 10mm thick |
Back cover | Anti-scratch Steel 1mm thick |
Side covers | 4 dissipators 40x250mm Anodized aluminum |
Top & bottom covers | Anti-scratch Steel 1mm thick |
Weight | 14.5 kg |
