RaspTouch RPI4 Black Chassis and Accessories Kit DIY
Reference : 11248
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 18-03-2025.
Caution : Rasptouch kits are designed for Raspberry Pi 4.
It is not possible to mount an older version.
Available in a separate room, this CNC aluminum case allows you to create any kind of personal project: controllers, home automation devices, professional screens and many others. All these applications using the official Raspberry Pi parts supplied with.
Suite the success of our KickStarter on the RaspTouchand to your multiple requests, we now put on sale the different models on our site.
Find here the RaspTouch DIY Kit including all necessary accessories and modules, compatible with Raspberry Pi 4:
  • The black aluminum housing complete with the black support for the official Raspberry Pi screen
  • The push button
  • The Micro SD 25cm extension
  • The interconnection screen for the official Raspberry Pi screen 20cm
  • The HDMI 30cm
This aluminum casing was designed by Audiophonics to receive all components specific to the RaspTouch, that is to say an ES9023 DAC or an ES9018K2M DAC, as well as a Raspberry Pi 4.
Specifications Case:
  • Housing 100% aluminumCNC machined (CNC machine)
  • Black Anodized / Chamfer
  • Dimensions: 200x95x230mm (Back panel: 175x55mm)
  • Weight: 840g
  • SD card slot
  • Port RJ45
  • HDMI port
  • USB-A x4 port
  • Port Jack DC 5.5 / 2.1mm x2
  • Analog stereo RCA output
  • Location button
  • Exclusive design
  • Useful internal dimensions of the housing (W x D x H) : 14 x 14 x 4.3cm
RapsTouch logo officiel
The RaspTouch was developed in order to offer all HiFi enthusiasts a simple, elegant, affordable, and especially High Resolution compatible solution to play your favorite music.
In useRaspberry Pi, we offer our customers the option of choosing the software solution they want and that is best suited to their needs. Solutions such as Picore Player, Kodi, Raspbian and Rune Audio have been tested and are working with our RaspTouch.
Forcombine with your Raspberry, you have the choice between an ES9023 24bit / 192kHz DAC or a 32bit / 384kHz ES9018K2M DAC. No matter your preference, you will get a high-end converter with uncompromising performance.
Here is a technical diagram showing the universe where the RaspTouch can be placed:
RaspTouch lecteur opensource - Schéma technique
- Video of presentation of the RaspTouch complete under Raspberry Pi 4 + DAC SABRE + Official screen 7 "-
MaterialMetal
Internal widthN/A
Internal depthN/A
Internal heightN/A
2 reviews
Very nice product, not the easiest to assemble
The RaspTouch IY kit is a very nice product. The parts are nicely machined, and the resulting built looks very good.
Audiophonics also provides a guide on how to put it together.
Where things do get a bit tricky is in the build: I think I was a bit unlucky as it turned out i did not receive all the screws needed for this build. Also it seems there are several iterations of the kit where some components are placed on a different location than described in the manual. The trickiest part I found was the SD card extension that had to be taken out of its casing and placed on the metal. As to make sure I would not short-circuit the piece, I first taped it up before fixing it to the metal.
Also because of these changes in the kit, not all steps and parts are self-explanatory anymore, which makes the build tricky.
But the support team is very helpful here and provides useful information and images to guide you through the steps.
Also in my case: they provided the parts I was missing, thank you guys!
Now I have this case set up with a raspberry model 3 B+ with touch and a DAC. As software I chose Moode Audio, and it sounds and functions perfectly.
This review has been posted for RaspTouch RPI4 Black Chassis and Accessories Kit DIY
Très bonne finition, dommage qu'il n'y ai pas de doc...
Je l'ai acheté pour faire un lecteur réseau avec une Pi3 sous Kodi/Xbian avec un DAC ES9023 TCXO V2.1 et un module ATX. La finition est excellente, la qualité des matériaux irréprochable. Pour les moins bricoleurs, il est dommage qu'il n'y ait pas de doc pour savoir quel sac de vis sert à quoi... mais une fois lancé on finit par y arriver. Bizarrement le lecteur micro SD est maintenant sous la Pi (non conforme au visuel) ce qui fait qu'au montage ça ne passe pas, faut laisser la carte SD à l'intérieur (problème de conception ?). Dommage qu'il n'y ait pas un ou deux fils de plus en spare pour alimenter par exemple Pi et écran... donc n'oubliez pas de rajouter des fils dans votre commande.
Je reste néanmoins complètement satisfait de l'achat. Pour ceux qui ne veulent pas se tracasser ou ne se sentent pas l'âme bricoleur/informatique, les kits complets ne sont finalement pas tellement plus cher que lorsqu'on se construit la sienne.
Foncez !
Bonjour!
Dans l'onglet téléchargement de la fiche est présent un manuel de montage DIY :)
