RaspTouch Silver Chassis and Accessories Kit DIY
Reference : 11249
115,00 €tax incl.
95,83 € tax excl.
Available in a separate room, this CNC aluminum case allows you to create any kind of personal project: controllers, home automation devices, professional screens and many others. All these applications using the official Raspberry Pi parts supplied with.
Suite the success of our cKickStarter on the RaspTouchand to your multiple requests, we now put on sale the different models on our site.
Find here the RaspTouch DIY Kitincluding all necessary accessories and modules, compatible with Raspberry Pi 2 and Pi 3:
  • The black aluminum housing complete with the silver support for the official Raspberry Pi screen
  • The push button
  • The Micro SD 25cm extension
  • The interconnection screen for the official Raspberry Pi screen 20cm
  • The HDMI 30cm
This aluminum casing was designed by Audiophonics to receive all components specific to the RaspTouch, that is to say an ES9023 DAC or an ES9018K2M DAC, as well as a Raspberry Pi 2 or Pi 3.
Specifications Case:
  • Housing 100% aluminumCNC machined (CNC machine)
  • Black Anodized / Chamfer
  • Dimensions: 200x95x230mm (Back panel: 175x55mm)
  • Weight: 840g
  • SD card slot
  • Port RJ45
  • HDMI port
  • USB-A x4 port
  • Port Jack DC 5.5 / 2.1mm x2
  • Analog stereo RCA output
  • Location button
  • Exclusive design
RapsTouch logo officiel
The RaspTouch was developed in order to offer all HiFi enthusiasts a simple, elegant, affordable, and especially High Resolution compatible solution to play your favorite music.
In useRaspberry Pi, we offer our customers the option of choosing the software solution they want and that is best suited to their needs. Solutions such as Picore Player, Kodi, Raspbian and Rune Audio have been tested and are working with our RaspTouch.
Forcombine with your Raspberry, you have the choice between an ES9023 24bit / 192kHz DAC or a 32bit / 384kHz ES9018K2M DAC. No matter your preference, you will get a high-end converter with uncompromising performance.
Here is a technical diagram showing the universe where the RaspTouch can be placed:
RaspTouch lecteur opensource - Schéma technique
- Video presentation of the RaspTouch under Raspberry Pi 3 + DAC SABER + Official screen 7 "-
MaterialMetal
Finitions exemplaires
L'attente fut longue, mais j'ai fini par être livré.
Et autant le dire tout de suite, ça valait le coup d'être patient.
Ok, certains trouveront le prix élevé, mais quand on voit la qualité de fabrication du produit, on se dit qu'on en a pour son argent.
Tout s'assemble au millimètre près, tout est solide... au final, c'est encore mieux que ce à quoi je m'attendais.
Quelques critiques tout de même (mais qui ne remettent pas en cause les 5 étoiles) :
- La carte d'alimentation n'est pas alignée au trou de la face arrière avec la même précision que le reste (y'a environ 1mm de décalage, je verrais si ça peut se rattraper... mais ça n'empêche pas le branchement de l'alim)
- il manque des bouchons pour combler les sorties RCA pour le cas où on n'utiliserait pas de DAC (pour ma part, je diffuse en Bluetooth)
- Pour être tatillon, il aurait pu y avoir une alimentation dans le package
- La description pour la mise en place du script de shutdown pourrait être dans la notice.
Un dernier point : le montage est globalement simple (merci la notice détaillée), mais compter une bonne heure pour tout mettre en place correctement.
 (3)
This review has been posted for RaspTouch Silver Chassis and Accessories Kit DIY
