JANTZEN AUDIO C-COIL 000-6003 Toroidal Coil Copper
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from overheating and without causing distortion.
Reference : 18750
41,90 €tax incl.
34,92 € tax excl.
Jantzen Audio C-Coil 000-6003Toroidal Coil Copper 14AWG Ø1.6mm 0.75mH 0.04 Ohm
Jantzen Audio C-Coil : Main view
Jantzen Audio's C-Coil toroidal coils feature very low resistance and excellent heat resistance. This means they can withstand high power levels without overheating or causing distortion. The model in question tolerates up to 1500W (RMS) / 8Ω . In fact, they are particularly effective for bass induction when filtering your passive hi-fi speakers.
Please note that due to the electromagnetic field inherent in their construction, C-Coils are not suitable for crossovers above 1.20kHz. Likewise, they are not intended for amplification or any other active system.
Each coil is individually tested with the CLIO @ AC 1V 1kHz measurement system.
Product typeToroidal coil
MaterialETP Copper C11000, IACS certified
CoreEpoxy-laminated steel plates
Inductance0.75mH ±5%
Power handling (RMS)1500W / 8Ω
RDC0.04Ω ±10%
Wire diameterØ1.6mm
Section2.081mm² (14AWG)
Outer diameterØ82mm
HeightØ26mm ±3
Weight490g
Inductance (mh)0.75
JANTZEN AUDIO C-COIL 000-6003 Toroidal Coil Copper 14AWG Ø1.6mm 0.75mH 0.04 Ohm
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from...
