JANTZEN AUDIO C-COIL 000-6122 4N Copper Toroidal Coil 12AWG Ø2mm 3mH 0.05 Ohm
Jantzen Audio's C-Coil Toroidal Coils have very low electric resistance and excellent heat tolerance. They can thus withstand high power without overheat-induced distorsion. This model can handle up to 2000W (RMS) / 8Ω . Because of this, Jantzen C-Coil make great inductors for passive filtering low-frequencies crossover.
Reference : 14752
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 29-04-2025.
Jantzen Audio C-Coil
Toroidal Copper Coil 12AWG Ø2mm 3mH 0.04 Ohm
Jantzen Audio C-Coil Bobine Torique Cuivre
Caution, due to the electromagnetic field inherent to their construction, C-Coils coils are not suitable for a crossover rising above 1.20kHz. Similarly, they are not intended for amplification or other active system.
Each coil is individually tested with the measurement system CLIO @ 1kHz AC 1V.
Product typeToroidal coil
MaterialETP Copper
C11000 Standard
IACS Certified
CoreEpoxy insulated metal
Inductance3mH ±5%
Power handling (RMS)2000W / 8Ω
RDC0.05Ω
External diameterØ95mm
Internal diameterØ32mm
Height32mm
Cable diameterØ2mm
Cable section12AWG
Weight880g
Inductance (mh)3.0
Jantzen Audio's C-Coil Toroidal Coils have very low electric resistance and excellent heat tolerance. They can thus withstand high power...
