JANTZEN AUDIO C-COIL 000-6165 4N Copper 14AWG Ø1.6mm 3.9mH 0.08 Ohm
Reference : 14477
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 29-04-2025.
Jantzen Audio toroidal coil / C-Coil
Bobine filtrage basses
Jantzen Audio's C-Coil Toroidal Coils have very low electric resistance and excellent heat tolerance. They can thus withstand high power without overheat-induced distorsion. This model can handle up to 1500W (RMS) / 8Ω . Because of this, Jantzen C-Coil make great inductors for passive filtering low-frequencies crossover.
Caution, due to the electromagnetic field inherent to their construction, C-Coils coils are not suitable for a crossover rising above 1.20kHz. Similarly, they are not intended for amplification or other active system.
Each coil is individually tested with the measurement system CLIO @ 1kHz AC 1V.
TypeETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
MaterialsCopper ETP Standard C11000 / Certified IACS
CoreEpoxy laminated steel plates
Inductance3,9mH +/-5%
RDC0,08Ω +/-10%
Power Handling (RMS)1500W (RMS) / 8Ω
Coil External Diameter87mm
Coil Height31mm
Coil Internal Diameter30mm +/-3
Wire Diameter1,60mm⌀
AWG14
Weight0,665kg
Inductance (mh)0.39
