JANTZEN AUDIO C-COIL 000-6390 4N Copper 12AWG Ø2mm 6.8mH 0.07 Ohm
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from overheating and without causing distortion. The model in question tolerates up to 2500W (RMS) / 8Ω . In fact, they are particularly efficient for bass induction when filtering your passive hi-fi speakers.
Reference : 17321
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 29-04-2025.
Jantzen Audio C-Coil - Toroidal Core Audio Inductor
Bobine filtrage basses
Attention, because of the electromagnetic field inherent to their construction, the C-Coils will not be suitable for a crossover rising beyond 1.20kHz. Also, they are not intended for amplification or any other active system.
Each coil is individually tested with the CLIO @ AC 1V 1kHz measurement system.
TypeToroidal core audio inductor
MaterialsCopper ETP Standard C11000 / IACS certified
CoreEpoxy insulated metal
Inductance6.8H +/-5%
Power handling (RMS)2500W (RMS) / 8Ω
RDC0.07 Ohm
Outer diameter107mm
Height37mm +/-3
Cable diameter2mm⌀
Cable section12AWG
Weigh1.28kg
Inductance (mh)6.8
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from...
