JANTZEN AUDIO C-COIL 000-6500 4N Copper 12AWG Ø2mm 10mH 0.09 Ohm
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from overheating and without causing distortion.
Reference : 15987
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 13-05-2025.
Bobine filtrage basses
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from overheating and without causing distortion. The model in question tolerates up to 2500W (RMS) / 8Ω. In fact, they are particularly efficient for bass induction when filtering your passive hi-fi speakers.
Attention, because of the electromagnetic field inherent to their construction, the C-Coils will not be suitable for a crossover rising beyond 1.20kHz. Also, they are not intended for amplification or any other active system.
Each coil is individually tested with the CLIO @ AC 1V 1kHz measurement system.
Product typeC-Coil
MaterialETP Copper C11000 standard / IACS certified
CoreEpoxy insulated metal
Inductance10mH +/-5%
Power handling (RMS)2500W / 8Ω
RDC0.09 Ohm
External diameter107mm
Height37mm +/-3
Internal diameter-
Wire diameter2mm
Wire AWG12AWG
Weight1.35kg
Inductance (mh)
  • 10.0
Jantzen Audio C-Coils have a very low resistance and excellent heat resistance. They can thus support high powers without suffering from...
