The Pangea Premier HD23PC HDMI cable looks like a cable that combines both high quality design and affordable price.
KEY FEATURES :
HDMI 1.4 Cable OFC Copper 24AWG 1m
The Pangea Premier HD23PC HDMI cable is a truly audiophile HDMI cable at an affordable price. Thanks to its flawless manufacturing quality, it will provide superior audio and video quality. The Pangea Premier HD23PC uses excellent materials and the experience of Pangea's engineers.
The quality of HDMI cables varies widely depending on two factors: the materials used and the way they are used. Taking these two factors into account, Pangea therefore chooses high quality OFC copper while adding premium multi-layer polyethylene foam insulation injected with nitrogen. An essential insulation to ensure a clean and stable signal.
Pangea HDMI cables are produced using the best Swiss machines, rarely used on this type of production. The precision of this equipment ensures that all cable pairs are of equal length, so that the signals reach the connectors simultaneously.
All tests of Pangea HDMI cables are performed by Time Domain Reflectometry to ensure that no cables suffer from synchronization problems.
The Pangea Premier HD23PC incorporates high-purity OFC copper conductors to ensure maximum conductivity. The cable also benefits from a braided nylon sheath, which gives it both strength and flexibility.
This cable also meets the HDMI 1.4 High-Speed standard for high bitrates and supports 4K files.
Conductors material | OFC Copper |
Conductors section | 24AWG |
Insulation | Premium Nitrogen-Injected Polyethylene Multi-Layer Foam dielectric |
Standard | HDMI 1.4 4K |
Colorimetry standard | RGB4:4:4 8bit (4K@24Hz, 4K@25Hz, 4K@30Hz) |
Sheath | Braided nylon |
Cable length | 1m |
Length (m) | 1.0 |
Shielding | NC |
Section (mm²) | 0.205 |
Connector | HDMI |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
