PANGEA PREMIER SE MKII HDMI 2.1 Cable Silver Plated Cardas Copper 8K 60Hz / 4K 120Hz HDR 48Gbps 0.6m
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity.
4.8 / 5
Reference : 13324
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 18-04-2025.
HDMI 2.1 Cable Silver Plated Cardas Copper 8K 60Hz / 4K 120Hz HDR 48Gbps0 0.6m
Pangea Audio Premier SE MKII Câble HDMI 2.1 Cuivre Cardas Plaqué Argent 8K 60Hz / 4K 120Hz HDR 48Gbps 1m
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity. Each conductor is insulated with a PE jacket and the whole cable is triple shielded to protect the signal from possible interferences that could alter its quality. The connectors are gold plated to guarantee a great durability.
Thanks to this optimal design, the Pangea Premier SE MKII benefits from a high badnwidth of 48Gbps, supports high resolution video streams up to 8K 60Hz and 4K 120Hz as well as HDR technology.
Product typeUSB cable
Length0.6m
Connectors2* Male HDMI
Cable diameterØ9.5mm
Conductors materialSilver plated Cardas copper
Conductors section0.205mm² (24AWG)
Conductors insulationPE
ShieldingTriple
Connectors contacts platingGold
Covering sheathBraided nylon
Bandwidth48Gbps
Max supported resolutions8K 60Hz
4K 120Hz
HDR support
ColorBlack and gray
Length (m)0.6
ShieldingYes
Section (mm²)0.205
ConnectorHDMI
6 reviews
Good cable but pay attention.
Everything is god with this cable. Just to notice is strong and unmanageable like a steel pipe. So pay attention to your i2s ports that can be forced following the cable. Sounds anyway really good.
This review has been posted for PANGEA PREMIER SE MKII HDMI 2.1 Cable Silver Plated Cardas Copper 8K 60Hz / 4K 120Hz HDR 48Gbps 0.6m
Excellent I2S cable.
I'm using this cable as I2S cable and it is highly recommended for this purpose. High quality build and robustness with excellent audio performance capabilities.
My first HDMI cable
I didn't now what to expect but this cable sounds really good. Pangea deliveries a good I2S cable. Like it!
Les produits Pangea sont excellents
Excellent
Utilisé seulement pour l’audio en liaison i2s entre streamer et Dac, le résultat ne pouvait pas être meilleur. Plus de silence dans la scène, transparent. Tout ce qu’un cable doit faire. Au départ j’étais réticent à cause du débit énoncé. En tout cas pour le son, c’est parfait. Je l’adopte. Merci Audiophonics.
Il me semble que tous les produits Pangea commencent à être « hors stock » pourquoi serait il?
Bonjour,
Pangea nous annonce des délais assez vague pour le 1er trimestre 2021 pour de nombreux produits.
C'est pourquoi nous préférons les mettre hors commande pour le moment, mais les produits ne sont pas définitivement arrêtés.
With the Pangea Premier SE MKII, you get a high quality HDMI 2.1 cable, allowing a perfect signal transmission between your devices. It consists of...
