HDMI 2.0 Cable Optical Fiber HDCP 2.2 4K HDR ARC 30m
This 30m long HDMI 2.0 cable is equipped with Copper and Fiber Optic conductors, ensuring high bandwidth for optimal signal transmission. Thus, the cable is compatible with 4K and UHD resolutions, as well as HDCP 2.2, ARC and HDR technologies.
Reference : 14906
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 22-04-2025.
HDMI 2.0 Cable
Câble HDMI 2.0 Fibre Optique HDCP 2.2 4K HDR ARC 30m
This HDMI 2.0 cable integrates fiber optic bundles as conductors. These ensure an excellent transmission rate of up to 18Gbps, very good signal stability and extremely low attenuation, while allowing the signal to be free from harmful electromagnetic interference. The cable is capable of transmitting 4K / UHD video signals at 60Hz and supports 3D, HDR ARC, and HDCP 2.2 technologies. Its connectors are gold plated to improve the durability of the product by giving them a very good resistance to corrosion and oxidation.
Product typeHDMI 2.0 Cable
ConductorsOptical fiber
Copper
Connectors platingGold
Length30m
ShieldingAluminum foil
Cable diameterØ4.5mm
Supported resolution4K*2K @ 60Hz
Bandwidth18Gbps
Supported technologiesHDR
UHD
HDCP 2.2
ARC
3D
Connectors body dimensions38 x 17.2 x 8.85mm
Sheath materialPVC
External sleeve materialPET
Length (m)30.0
ShieldingYes
Section (mm²)N/A
ConnectorHDMI
Conductors material (Cable)Optical Fiber
This 30m long HDMI 2.0 cable is equipped with Copper and Fiber Optic conductors, ensuring high bandwidth for optimal signal transmission. Thus, the...
