HDMI 2.0 Optical Cable 4K 60Hz 18Gbps UHD HDR 10 DHCP 2.2 EDID CEC eARC 3D 3m
This 3m-long optical HDMI 2.0 cable supports high-definition video streams up to 4K 60Hz, with a maximum bandwidth of 18Gbps, and is compatible with CEC, 3D, HDR 10, eARC, DDC, EDID and DHCP 2.2 technologies.
Reference : 17975
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 22-04-2025.
HDMI 2.0 Optical cable
Câble HDMI 2.0 Optique 4K 60Hz 18Gbps UHD HDR 10 DHCP 2.2 EDID CEC eARC 3D 3m
This 3m-long optical HDMI 2.0 cable supports high-definition video streams up to 4K 60Hz, with a maximum bandwidth of 18Gbps, and is compatible with CEC, 3D, HDR 10, eARC, DDC, EDID and DHCP 2.2 technologies. It uses fibre optic conductors, allowing transmission over long distances without interference, combined with tinned copper conductors. A general shielding repels any interference that might alter the signal passing over the copper conductors. The connectors feature gold-plated, oxidation-resistant contacts with a zinc alloy body that also reduces the risk of electromagnetic interference.
Product typeOptical HDMI cable
HDMI version2.0
Length3m
Conductors materialOptical fibre
Tinned copper
Shielding
Connectors contacts platingGold
Connectors body materialZinc alloy
Max supported resolutions4K @ 60Hz
Bandwidth18Gbps
Supported technologiesCEC
HDR
HDR 10
3D
DHCP 2.2
eARC
DDC
EDID
Color space4:4:4 max.
Color depth12bit max.
Outer diameterØ5.2mm
Length (m)3.0
ShieldingYes
Section (mm²)N/A
ConnectorHDMI
Conductors material (Cable)Optical Fiber
This 3m-long optical HDMI 2.0 cable supports high-definition video streams up to 4K 60Hz, with a maximum bandwidth of 18Gbps, and is compatible...
