KAIBOER KBEH-A2.0 HDMI 2.0 Cable ULTRA HD 2160p 18Gbps 4K 3m
Reference : 9379
36,90 €tax incl.
30,75 € tax excl.
Here is the new generation of HDMI 2.0 cables.
The brand Kaiboer offers here cables with irreproachable finishes and great elegance.
With high bandwidth up to 18Gbps, they are designed for all types of Full HD, 2K, 4K (UHD) TVs and are obviously compatible with devices with previous HDMI ports (1.3, 1.4).
Cette versatility goes beyond: they are designed to support the wide angle 21: 9 and 3D.
HDMI 2.0 cables allow you to stream 2 Ultra High Definition video streams on the same screen simultaneously.
They benefit from Deep Color technology for deeper colors that allows you to transmit additional color information to the TV, and thus benefit from sublimated colors.
Finally, thexvYCC (Extended-gamut YCC) technology enhances the color space used to enjoy more subtle colors than those offered by a conventional cable.
Du Audio side, they are not left behind.
tout First, the Audio Return Channel allows you to make sound pass in both directions.
Second, Dolby TrueHD is an uncompressed audio format that can support up to 7 channels.
Finally, the DTS-HD Master Audio technology allows you to have 8 lossless channels at a sampling rate of 24bit / 192kHz.
Characteristics :
  • HDMI A male
  • 2160p to 50/60Hz
  • Up to 32 audio channels
  • Bandwidth: 18Gbps
  • 3D Compatible
  • CEC (Inter-element control)
  • Ethernet Channel
  • Audio Return Channel
  • xvYCC
  • Dolby TrueHD
  • DTS-HD Master Audio
  • Braided PVC sheath Nylon
  • Insulation: Mylar shielding sheet, Tinned copper and PE high density foam (Japan)
  • Conductor Copper OFC 4N 0.0810mm² 28AWG
  • 24K Gold Plated Connectors
  • Metal body
  • External Diameter: 8.3mm
  • Length: 3m
  • Weight: 272g
Kaiboer KBEH-A2
Kaiboer KBEH-A2
Kaiboer KBE-HD-1011
Length (m)3.0
ShieldingYes
Section (mm²)0.0810
ConnectorHDMI
