Câble HDMI 2.0 High Speed Triple Blindage Plaqué Or 24k 1m
Lindy's Cromo Line represents the brand's range of high-performance HDMI 2.0 High Speed cables. These cables have triple shielding and tinned copper conductors with a cross-section of 28AWG (0.0810mm²) providing excellent signal conductivity and lossless transmission. The connectors of these cables are 24k Gold plated for high resistance to oxidation and corrosion, for increased durability.
On the video side, these cables support resolutions up to 4K 4096w2160@60Hz 4:4:4:4 8bit, as well as 3D. On the audio side, they are capable of supporting up to 32 channels as well as Dolby True HD.
The connector housing is made of a solid chrome-plated ABS. Ultra-flexible sleeves ensure resistance to mechanical stresses (twisting, pulling, etc.) to meet the requirements of industrial and advertising audiovisual applications.
The Lindy Cromo also complies with the new HDMI specifications and supports 18G bandwidth (for lengths up to 5m).
General specifications | |
Product type | HDMI Cable |
Bandwith | 18 Gbit/s |
Max resolution | 4096 x 2160px @ 60Hz 4:4:4: 8bit |
Nominal attenuation | 300kHz - 825MHz < 5dB 825MHz - 2.475GHz < 5dB 2.475GHz - 4.125GHz < 12dB 4.125GHz - 5.1GHz < 20dB |
Minimum bending radius | 60mm (2.36") |
Operating temperature | 10°C - 80°C (14°F - 176°F) |
Cable specifications | |
Length | 1m (3.3ft) |
Standard | High Speed HDMI with Ethernet |
Color | Gray |
Type | Round |
Sheath diameter | 73mm (0.29") |
Sheath material | PVC |
Conductors material | Tinned Copper |
Conductors section | 0.0810mm² (28AWG) |
Shielding | Braided Copper (cover: 85%) |
Connectors specifications | |
Connectors type | 2x Male Type A HDMI |
Shell material | ABS, chromed |
Connectors plating | Gold 24k 3µm |
Contacts material | Copper alloy |
Contacts plating | Gold 24k 15µm |
Dimensions | Approx. 20 x 11.6 x 34.1mm |
Color |
Material |
Length (m) |
Insulation material |
Shielding |
Connectic |
Section (mm²) |
Connector |
