LINDY CROMO LINE High Speed HDMI 2.0 Cable Triple Shielding 24k Gold Plated 3m
Lindy's Cromo Line represents the brand's range of high-performance HDMI 2.0 High Speed cables. These cables have triple shielding and tinned copper conductors with a cross-section of 28AWG (0.081mm²) providing excellent signal conductivity and lossless transmission.
Reference : 13465
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 22-04-2025.
Lindy Cromo Line
Câble HDMI 2.0 High Speed Triple Blindage Plaqué Or 24k 3m
Lindy Cromo Line Câble HDMI 2.0 High Speed Triple Blindage Plaqué Or 24k 3m
Lindy's Cromo Line represents the brand's range of high-performance HDMI 2.0 High Speed cables. These cables have triple shielding and tinned copper conductors with a cross-section of 28AWG (0.0810mm²) providing excellent signal conductivity and lossless transmission. The connectors of these cables are 24k Gold plated for high resistance to oxidation and corrosion, for increased durability.
On the video side, these cables support resolutions up to 4K 4096w2160@60Hz 4:4:4:4 8bit, as well as 3D. On the audio side, they are capable of supporting up to 32 channels as well as Dolby True HD.
The connector housing is made of a solid chrome-plated ABS. Ultra-flexible sleeves ensure resistance to mechanical stresses (twisting, pulling, etc.) to meet the requirements of industrial and advertising audiovisual applications.
The Lindy Cromo also complies with the new HDMI specifications and supports 18G bandwidth (for lengths up to 5m).
General specifications
Product typeHDMI Cable
Bandwith18 Gbit/s
Max resolution4096 x 2160px @ 60Hz 4:4:4: 8bit
Nominal attenuation300kHz - 825MHz < 5dB
825MHz - 2.475GHz < 5dB
2.475GHz - 4.125GHz < 12dB
4.125GHz - 5.1GHz < 20dB
Minimum bending radius60mm (2.36")
Operating temperature10°C - 80°C (14°F - 176°F)
Cable specifications
Length3m (9.84ft)
StandardHigh Speed HDMI with Ethernet
ColorGray
TypeRound
Sheath diameter73mm (0.29")
Sheath materialPVC
Conductors materialTinned Copper
Conductors section0.0810mm² (28AWG)
ShieldingBraided Copper (cover: 85%)
Connectors specifications
Connectors type2x Male Type A HDMI
Shell materialABS, chromed
Connectors platingGold 24k 3µm
Contacts materialCopper alloy
Contacts platingGold 24k 15µm
DimensionsApprox. 20 x 11.6 x 34.1mm
Length (m)3.0
ShieldingYes
Section (mm²)0.0810
ConnectorHDMI
4 reviews
Le top
Aussitôt reçu aussitôt branché il est très épais donc ce courbe peu, faut le prendre en compte mais fonctionne parfaitement j'en rachète un de suite on sent la qualité et on l'entend !
This review has been posted for LINDY CROMO LINE High Speed HDMI 2.0 Cable Triple Shielding 24k Gold Plated 3m
parfait RQP
Liaison directe box canal Tv,
amélioration perceptivle couleur et netteté par rapport à du basique. Surement du au bln blindage. Je recommande sans réserves à ce prix.
Qualité / prix excellent
Ont remplacé mes liaisons décodeur et Blu-ray vers tV.
Par rapport à des monsters(qui avaient plus de 4ans donc peu être oxydés..)
J ai gagné sur les deux dispositifs en clarté d image et netteté. Perceptible.L image est plus franche
Donc forcément 5 étoiles vu l investissement.
[Le choix a été fait aussi vu que j ai un usb3 de la gamme (pc dac) m ayant donné précédemment satisfaction.]
Bémol à la livraison qui a pris près d un mois..
Item arrived fast and in well packed plastic zip bag. Cable looks strong an durable and have gold platet connectors with safe plastic caps.
Lindy's Cromo Line represents the brand's range of high-performance HDMI 2.0 High Speed cables. These cables have triple shielding and...
