LINDY GOLD LINE High Speed HDMI 2.0 Cable OFC Copper Gold Plated Triple Shielding 24k 2m
Lindy cables in the Gold Line range provide high quality interconnections through uncompromising design. This HDMI 2.0 High Speed cable features triple shielding and 24AWG OFC copper conductors for optimal transmission without losses. The connectors and contacts are 24k gold plated, ensuring corrosion resistance and high reliability.
Reference : 14416
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 22-04-2025.
Lindy Gold Line HDMI
Lindy Gold Line Câble HDMI 2.0 High Speed Cuivre OFC Plaqué Or Triple Blindage 24k 2m
UHD resolutions up to 4K 4096x2160 @ 60Hz 4:4:4 8 bit are supported. This HDMI cable can also transmit 32 channels of audio and Dolby True HD. In addition, it provides very low attenuation for reliable transmission.
Gold Line HDMI 2.0 cables meet the new HDMI specifications and support 18G bandwidth.
Product typeHDMI Cable
ConnectorsMale HDMI
Length2m
StandardHDMI 2.0 High Speed
Cable diameterØ8.5mm
Cable conductors materialOFC Copper
Cable conductors section0.205mm² (24AWG)
Cable triple shieldingBraided Copper (Cover 85%)
Cable sheath materialPVC
Connectors platingGold 24k 3µm
Connectors contacts materialCopper alloy
Connectors contacts platingGold 24k 15µm
Connectors body materialGold 24k plating and Zinc alloy
Connectors dimensions20 x 34.1 x 11.6mm
Bandwidth support18GBit/s
Max resolution4096 x 2160 @ 60Hz 4:4:4 8bit
Nominal attenuation300kHz - 825MHz < 5dB
825MHz - 2.475GHz < 5dB
2.475GHz - 4.125GHz < 12dB
4.125GHz - 5.1GHz < 20dB
Min. bending radius85mm
Operating temperature-10°C / 80°C
Compatible technologies3D, 4K, HEC, ARC, CEC, Dolby True HD, DTS-HD Master Audio
CertificationsATC, RoHS, REACH, UL
ColorsCable: Gray
Connectors : Gold
Length (m)2.0
ShieldingYes
Section (mm²)0.205
ConnectorHDMI
Lindy cables in the Gold Line range provide high quality interconnections through uncompromising design. This HDMI 2.0 High Speed cable features...
