Optical Fiber HDMI 2.0 Cable HDCP 2.2 4K HDR ARC 10m
This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low attenuation while allowing the signal not to be subjected to high levels of electromagnetic interference.
Reference : 13791
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 22-04-2025.
Optical Fiber HDMI Cable
Câble HDMI 2.0 Fibre Optique HDCP 2.2 4K HDR ARC 5m
This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low attenuation while allowing the signal not to be subjected to electromagnetic interference. The cable is capable of transmitting 4K / UHD video signals in 60Hz and supports 3D, HDR ARC, and HDCP 2.2 technologies. Its connectors are gold plated to improve the durability of the product by providing very good corrosion and oxidation resistance.
13790-cable-hdmi-fibre-optique-inpage2.j  Dimensions connectors
This cable is not compatible with I2S LVDS links
Be careful not to make too many knots or elbows with the cable, as this could break the optical fiber.
Product typeOptical Fiber HDMI 2.0 Cable
Length10m
Conductors4x Optical fibers
Bandwith18Gbps
Cable diameterØ4.5mm
Connectors2x male HDMI Type A
Connectors platingGold
Supported video resolution4K @ 60Hz
Supported technologiesHDR
HDCP 2.2
3D
Sheath colorGray
Length (m)10.0
ShieldingYes
Section (mm²)N/A
ConnectorHDMI
Conductors material (Cable)Optical Fiber
2 reviews
Excellent câble
Ce câble remplace avantageusement un ancien câble hdmi, certifié 1.4, qui ne permettait pas de faire passer correctement de la 4k, Dolby vision/HDR10+.
A présent c'est fluide et parfaitement reconnu par la TV, qui applique ces paramètres les plus poussés sans soucis, également dans le cas du Gaming à 60fps.
Ce câble HDMI 2.0 est 3 fois plus fin et souple que mon précédent câble 1.4
Commande passé un mercredi soir, livré le vendredi midi, dans un colis bien protégé.
This review has been posted for Optical Fiber HDMI 2.0 Cable HDCP 2.2 4K HDR ARC 10m
Parfait à résolu mes problèmes de jitter
J'ai acheté ce câble pour remplacer un classique belkin de 10 m.
J'ai un emotiva UMC 10 et un vieux panasonic full HD (HFDMI 1.4 sans doute).
J'avais des mouches blanche sur les images sombres.
Maintenant c'est nickel.
Ce câble m'a été conseillé par Audiophonics par échage de mail.
Le signal transite par fibre optiques. les convertisseurs sont dans les prises. il est fin, bien présenté.
Bon achat.
This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal...
