Optical Fiber HDMI 2.0 Cable HDCP 2.2 4K HDR ARC 2m
This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low attenuation while allowing the signal not to be subjected to high levels of electromagnetic interference.
Reference : 13802
49,90 €tax incl.
41,58 € tax excl.
Optical Fiber HDMI Cable
Câble HDMI 2.0 Fibre Optique HDCP 2.2 4K HDR ARC 5m
This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low attenuation while allowing the signal not to be subjected to electromagnetic interference. The cable is capable of transmitting 4K / UHD video signals in 60Hz and supports 3D, HDR ARC, and HDCP 2.2 technologies. Its connectors are gold plated to improve the durability of the product by providing very good corrosion and oxidation resistance.
13790-cable-hdmi-fibre-optique-inpage2.j  Dimensions connectors
This cable is not compatible with I2S LVDS links
Be careful not to make too many knots or elbows with the cable, as this could break the optical fiber.
Product typeOptical Fiber HDMI 2.0 Cable
Length2m
Conductors4x Optical fibers
Bandwith18Gbps
Cable diameterØ4.5mm
Connectors2x male HDMI Type A
Connectors platingGold
Supported video resolution4K @ 60Hz
Supported technologiesHDR
HDCP 2.2
3D
Sheath colorGray
Length (m)2.0
ShieldingYes
Section (mm²)N/A
ConnectorHDMI
Conductors material (Cable)Optical Fiber
This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal...
