Optical Fiber HDMI 2.0 Cable HDCP 2.2 4K HDR ARC 5m
This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low attenuation while allowing the signal not to be subjected to electromagnetic interference. The cable is capable of transmitting 4K / UHD video signals in 60Hz and supports 3D, HDR ARC, and HDCP 2.2 technologies. Its connectors are gold plated to improve the durability of the product by providing very good corrosion and oxidation resistance.
This cable is not compatible with I2S LVDS links
Be careful not to make too many knots or elbows with the cable, as this could break the optical fiber.
Product type | Optical Fiber HDMI 2.0 Cable |
Length | 5m |
Conductors | 4x Optical fibers |
Bandwith | 18Gbps |
Cable diameter | Ø4.5mm |
Connectors | 2x male HDMI Type A |
Connectors plating | Gold |
Supported video resolution | 4K @ 60Hz |
Supported technologies | HDR HDCP 2.2 3D |
Sheath color | Gray |
Length (m) | 5.0 |
Shielding | No |
Section (mm²) | N/A |
Connector | HDMI |
Conductors material (Cable) | Optical Fiber |
Conductors Plating (Cable) | None |
