Viablue S-920 HDMI Silver HIGH SPEED - HDMI V2.0B 0.75m Ethernet
Reference : 11816
105,00 €tax incl.
87,50 € tax excl.
Vibalue's high-end HDMI cable designer uses only premium materials. These 4K HDMI cables are made of strong multi-stranded OFC copper providing a high level of transfer to the HIGH SPEED HDMI 2.0B standard. In order to ensure a safe transfer quality, this HDMI 2.0 cable is equipped with a triple shielding at 100% guaranteeing a signal freed from any external noise interference. The ferrites on each side of this cable guarantee mechanical stability, effective suppression of EMI electromagnetic interference.
The Vi finishablue Cobra, polymer mesh alloy guarantees high durability and electromechanical qualities even after many years of use.
Features:
  • Standard HDMI 2.0B HIGH SPEED
  • Retro compatible old standards HDMI
  • Triple shielding (2 Shields + 1 shielding braid) + Ferrite
  • Conductors COPPER OFC silver plated
  • Gold plated connectors 24k
  • Resolution up to 2160p (4096 x 2160 pixels) @ 50 / 60hz 4K UHD
  • High Dynamic Range video
  • Compatible with dynamic synchronization of video and audio streams
  • Networking compatibility: Ethernet 100 mbit
  • Audio Return Channel (ARC)
  • Transfer rate: 18 GBIT / S over 8 bit YUV 4.2.0
  • Able to manage 32 audio channels
  • Audio sampling capacity up to 1536 Khz
  • Compatible: Dolby Digital plus, True HD,
  • Copper Section: 24 AWG
  • External diameter of the cord: 10.5 mm
  • Max Connector Width: 24mm
  • Compliant with standards: HDCP, HDMI, ROHS
Length (m)0.7
ShieldingYes
Section (mm²)N/A
ConnectorHDMI
