Adhesive Cable Tie 20x20mm Black (Set x100)
This adhesive cable tie simply attaches to a wall to allow you to group your cables together. The base of the cable tie is adhesive and can therefore be easily attached to any surface. However, two holes allow the fastener to be screwed in for a firmer hold.
Reference : 15914
9,90 €tax incl.
8,25 € tax excl.
Cable tie
Attache Câble Adhésif 20x20mm Noir
A hose clamp, sold separately (see accessories), is required to attach your cables. This product corresponds to the base of the attachment system.
Product typeCable tie
Dimensions20 x 20 x 6mm
Adhesive
Fixation holes spacing13mm
Dimensions of hose clamp mounting space6 x 2.5mm
Quantity100 units
MaterialPlastic
Length (m)Sold by length
Section (mm²)N/A
Conductors material (Cable)N/A
This adhesive cable tie simply attaches to a wall to allow you to group your cables together. The base of the cable tie is adhesive and can...
